01-05-2016 05:35 PM
2,975 ... 8081828384 ...
tools
  1. reverendjoe's Avatar
    Great battery life + stability with cm9 beta 2. However, I've never had success with any governers but interactiveX, and am wondering why I often hear savagedzen is recommended. I'm not contesting anyone, just curious as to what it is about that governer that makes it recommended. Always been very stable at 320/787 interactive and this gives excellent battery as well.
    Love tdm and all devs, thank you for your time, effort, and contributions to this community.
    tdm likes this.
    08-12-2012 10:10 PM
  2. HurrrDurrrDURP's Avatar
    TDM will you be making a new build with the lastest CM9 source? So we can rule out if it was the kernel glitching and not CM9?
    08-12-2012 10:23 PM
  3. tdm's Avatar
    I'll check but I don't think anything relevant changed from beta2.
    08-12-2012 10:51 PM
  4. cbucz24's Avatar
    http://forum.xda-developers.com/show...php?p=28647926
    This thread explains all governors.
    Sent from my PC36100 using Tapatalk 2
    reverendjoe likes this.
    08-12-2012 11:34 PM
  5. HurrrDurrrDURP's Avatar
    Good new everyone! I found the reason why voice search is broken on our phones!
    It seems the AMR encoder(The software used to record our voice) seems to be throwing an error every time it is initialized!
    tdm do you think this could be fixed or find a work around?
    Full log cat
    Code:
    I/AudioHardwareMSM72XX( 1745): do input routing device 400000
    I/AudioHardwareMSM72XX( 1745): Routing audio to Speakerphone
    D/AudioHardwareMSM72XX( 1745): doAudioRouteOrMute() device 0, mMode 0, mMicMute 1, mBuiltinMicSelected 1, muted
    I/AudioService( 1863):  AudioFocus  requestAudioFocus() from android.media.AudioManager@40de8e38com.google.android.voicesearch.speechservice.GrecoRecognizer$1@40dea608
    I/ConnectionFactoryImpl( 2608): Opening SSL connection: vs.google.com:14259
    I/MicrophoneInputStream( 2608): #close - audio release
    I/AudioHardwareMSM72XX( 1745): set device to SND_DEVICE_SPEAKER device_id=0
    I/AudioHardwareMSM72XX( 1745): Enabling post proc features with mask 0x0000
    D/dalvikvm( 1863): GC_EXPLICIT freed 593K, 43% free 5370K/9351K, paused 8ms+38ms
    I/RecognitionEngineRetrier( 2608): #onError - notify
    I/AudioService( 1863):  AudioFocus  abandonAudioFocus() from android.media.AudioManager@40de8e38com.google.android.voicesearch.speechservice.GrecoRecognizer$1@40dea608
    E/UberRecognizerController( 2608): onError
    E/UberRecognizerController( 2608): com.google.android.voicesearch.speechservice.connection.AudioRecognizeException: Error thrown by AMR encoder
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.speechservice.NetworkRecognitionEngine.startSendLoop(NetworkRecognitionEngine.java:153)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.speechservice.NetworkRecognitionEngine.internalStartRecognition(NetworkRecognitionEngine.java:129)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.speechservice.NetworkRecognitionEngine.startRecognition(NetworkRecognitionEngine.java:84)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.speechservice.RecognitionEngineWrapper.startRecognition(RecognitionEngineWrapper.java:50)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.speechservice.RecognitionEngineRetrier.startRecognition(RecognitionEngineRetrier.java:93)
    E/UberRecognizerController( 2608): 	at java.lang.reflect.Method.invokeNative(Native Method)
    E/UberRecognizerController( 2608): 	at java.lang.reflect.Method.invoke(Method.java:511)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.util.ThreadChanger$1$1.run(ThreadChanger.java:63)
    E/UberRecognizerController( 2608): 	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:442)
    E/UberRecognizerController( 2608): 	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:305)
    E/UberRecognizerController( 2608): 	at java.util.concurrent.FutureTask.run(FutureTask.java:137)
    E/UberRecognizerController( 2608): 	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:150)
    E/UberRecognizerController( 2608): 	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:264)
    E/UberRecognizerController( 2608): 	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1076)
    E/UberRecognizerController( 2608): 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:569)
    E/UberRecognizerController( 2608): 	at java.lang.Thread.run(Thread.java:856)
    E/UberRecognizerController( 2608): Caused by: java.io.IOException: couldn't start recording, state is:1
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.endpointer.MicrophoneInputStream.ensureStarted(MicrophoneInputStream.java:92)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.endpointer.MicrophoneInputStream.read(MicrophoneInputStream.java:127)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.endpointer.BluetoothAwareMicrophoneInputStream.read(BluetoothAwareMicrophoneInputStream.java:82)
    E/UberRecognizerController( 2608): 	at com.google.common.io.ByteStreams.read(ByteStreams.java:806)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.audio.reader.Tee.fillBuffers(Tee.java:257)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.audio.reader.Tee.get(Tee.java:171)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.audio.reader.Tee$TeeInputStream.read(Tee.java:368)
    E/UberRecognizerController( 2608): 	at java.io.InputStream.read(InputStream.java:163)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.speechservice.AudioSource.captureLoop(AudioSource.java:89)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.speechservice.AudioSource.access$000(AudioSource.java:25)
    E/UberRecognizerController( 2608): 	at com.google.android.voicesearch.speechservice.AudioSource$1.run(AudioSource.java:63)
    E/UberRecognizerController( 2608): Got error after recognizing []
    I/AudioHardwareMSM72XX( 1745): disabling post proc features with mask 0x0000
    I/AudioService( 1863): AudioFocus abandonAudioFocus() from android.media.AudioManager@40de8e38c...service.GrecoRecognizer$1@40dea608
    E/UberRecognizerController( 2608): com.google.android.voicesearch.speechservice.connection.AudioRecognizeException: [HL]Error thrown by AMR encoder[/HL]
    tdm likes this.
    08-13-2012 12:08 AM
  6. tdm's Avatar
    Thanks, I'll take a look.
    08-13-2012 12:19 AM
  7. drm1992's Avatar
    Havent been on for a while but I guess mms is broken on nightly 7/31 aokp. Go SMS as a work around. Could it be a bad flash caused by a dirty flash?
    08-13-2012 12:59 AM
  8. jccjr1982's Avatar
    I think I uncovered another bug: When you try to send a text message over 160 characters, it will attempt to send, but error out instead of automatically sending multiple texts (as stock or IHO roms did). So basically truncate or cut n paste half the message to new text. This issue is on AOKP; haven't tested it on CM.
    I absolutely love this ROM. I tried going back to IHO roms until at least the video and deep sleep problems are fixed, but I've gotten too accustomed to and came running back. Seriously once the current known bugs are fixed, this rom will be PERFECT for this phone and I can't see why anyone would want to use anything else. Keep up the great work tdm!
    tdm likes this.
    08-13-2012 02:08 AM
  9. strabo231's Avatar
    Maybe a dumb question, but did you select the split setting for messages over 160 characters in the messaging settings?
    jccjr1982 likes this.
    08-13-2012 02:32 AM
  10. drew_t's Avatar
    Same here, for what it's worth. Battery life is at least as good as stock or Backside. I don't overclock; I leave the performance settings at the defaults. AFAIK, no spontaneous reboots since I flashed the Beta 2.
    08-13-2012 02:59 AM
  11. bennettg's Avatar
    Did the final cm fix the hotspot problem?
    08-13-2012 08:29 AM
  12. chcub1's Avatar
    Uh, just wondering how do we know if there's an update to the ROM? And how do you install it?
    08-13-2012 09:10 AM
  13. rmwutr's Avatar
    my phone freezes up at random things like checking messages, or email, etc and I have to take the battery out to restart. pressing power button doesn't help. This also happens when it's on sleep and I get a text or a call or something.
    Is this a known bug and is there any fix? any help would be appreciated. I love this ROM and want to keep it.
    Thanks
    08-13-2012 10:02 AM
  14. nitestalkr's Avatar
    You install it just as any other rom, and you check the host sites for updates.
    sent from my G-T-R Reloaded V
    08-13-2012 10:03 AM
  15. andrewnelson23's Avatar
    @tdm. Is there any chance you could make a button combo for screenshots?
    08-13-2012 11:29 AM
  16. tdm's Avatar
    Probably something for a modder to do.
    But you can add screenshot to the power menu, check through the settings it's in there somewhere.
    08-13-2012 11:39 AM
  17. anthonycr's Avatar
    I'm pretty sure there already is a button combo... I use it on bobz ICS anyway... power and volume down
    andrewnelson23 likes this.
    08-13-2012 11:44 AM
  18. kcls's Avatar
    Yup, that's it. But you have to hold the buttons down for a second or two before it'll take the screenshot. That threw me off at first.
    08-13-2012 11:47 AM
  19. andrewnelson23's Avatar
    Yesssss there is! That worked, thanks Anthony. Yeah tdm I had it in the power menu.
    08-13-2012 11:48 AM
  20. Rudeco's Avatar
    So ever since flashing the egl patch I've been able to overclock cm9 beta 2 with pretty much zero problems. But, why is my download speeds so dang low. At like 25 kbps opposed to 178kbps I got early this morning while running my GTR cm7. I'm stumped. Maybe its just network traffic .
    08-13-2012 12:33 PM
  21. andrewnelson23's Avatar
    you could change your prl. i got WAY better data speeds after doing that.
    08-13-2012 12:58 PM
  22. cbucz24's Avatar
    Not saying it couldn't happen, but the PRL shouldn't have any effect on your data. Its a list of what towers you connect to.
    But in theory, if you had additional towers you weren't using it could help.
    08-13-2012 01:35 PM
  23. cbucz24's Avatar
    Try this from xda
    http://forum.xda-developers.com/show...php?p=24139905
    It helped me quite a bit. Sry, forgot to add that to my flash list
    08-13-2012 01:37 PM
  24. chcub1's Avatar
    So how do I check? If there's an update? Where will it say it? And do I just flash it or would I have to wipe everything? And does anyone know a good video player? Mx player isn't working
    08-13-2012 03:45 PM
  25. sellers86's Avatar
    Try volume down and power at the same time. That is supposed to be native to ICS and it works on one of my tablets.
    08-13-2012 03:55 PM
