01-05-2016 05:35 PM
2,975 ... 8283848586 ...
tools
  1. Rayz321's Avatar
    I'm on nightly build CM9 20120721 and I found a bug.
    If you have the camera open and then you lock the screen and then unlock it the whole screen will be blue and green and fuzzy. If you exit the camera app it returns to normal but it always happens once you lock the screen with the camera app open
    tdm likes this.
    08-14-2012 12:21 AM
  2. BuggerZ's Avatar
    Looks at this tweak guide. Maybe we can use some of them in the official ROM?
    08-14-2012 07:18 AM
  3. blizard's Avatar
    Goo.im not showing tdm how/were do i get the new nightly
    08-14-2012 07:18 AM
  4. jonny5449's Avatar
    No new nightlies but getquattrimus.com has new betas just click on mirror 2
    Sent from my LG-LS670 using Tapatalk 2
    08-14-2012 07:47 AM
  5. tdm's Avatar
    Many of these are already there. If you find any that are particularly helpful, let us know.
    08-14-2012 07:51 AM
  6. brotherswing's Avatar
    Potential bug. I reported several pages back that sometimes my phone doesn't lock. Hit the power button, and there's the home screen - no lock screen. I've noticed it's does it a couple of times a day. When the lock screen does decide to work, it kicks in regardless of whether you're using the phone or not. I haven't been able to spot any pattern to the behavior yet, but I'm keeping an eye on it. I don't use a pattern or anything, just the regular lock screen. I'm not bothered by it, but others might be...
    sent from the hip.
    sellers86 likes this.
    08-14-2012 11:00 AM
  7. andrewnelson23's Avatar
    You could go to the setting of the default profile and select lock screen insecure. Then go to lockscreens and set one up. It won't actually lock your screen, but that might fix your problem. You can't pull down notifications from lock screen if you do this though.
    08-14-2012 12:34 PM
  8. tvall's Avatar
    Well on the htc dream and sapphire, we have 4 different radio/spl combinations each requiring different kernels. Many recent roms automatically detect and install the needed one in the updater-script. What tdm described seems a lot more awesome than that.
    08-14-2012 12:51 PM
  9. capslock118's Avatar
    I wanted to say thanks for this ROM; it's awesome on my phone.
    Unfortunate that the wi-fi AP doesn't work since my nexus 7 doesn't accept ad-hoc networks. Maybe I'll root my nexus 7 to make it work.
    tdm likes this.
    08-14-2012 12:51 PM
  10. andrewnelson23's Avatar
    What good is an unrooted nexus 7? that thing was made to be rooted.
    08-14-2012 02:07 PM
  11. TauSigmaNova's Avatar
    What good is an unrooted ANDROID DEVICE!
    08-14-2012 02:36 PM
  12. nitestalkr's Avatar
    I hear they make good paperweights
    sent from my Zom-"Bean'(CM10 JellyBean).
    andrewnelson23 likes this.
    08-14-2012 02:40 PM
  13. Rudeco's Avatar
    Anyone experienced this? On AOKP beta 2, toggled airplane mode and phone data won't work now. Toggled data a few times and still no luck. Flashed my gtr cm7 rom and data works fine.
    08-14-2012 02:46 PM
  14. nitestalkr's Avatar
    Did you try turning off airplane mode?
    And the rebooting?
    08-14-2012 02:56 PM
  15. Rudeco's Avatar
    And the rebooting?
    Yes and multiple reboots
    08-14-2012 03:03 PM
  16. nitestalkr's Avatar
    That's strange.. I can't seem to recreate the issue
    sent from my un-dead sammich(AOKP Quattrimus)
    08-14-2012 03:08 PM
  17. Rudeco's Avatar
    I know. Its very weird. Smh.
    08-14-2012 03:10 PM
  18. chcub1's Avatar
    So how do I check? If there's an update? Where will it say it? And do I just flash it or would I have to wipe everything? And does anyone know a good video player? Mx player isn't working.
    08-14-2012 03:19 PM
  19. chcub1's Avatar
    So how do I check? If there's an update? Where will it say it? And do I just flash it or would I have to wipe everything? And does anyone know a good video player? Mx player isn't working. And is it possible to add adobe flash player somehow?
    08-14-2012 03:22 PM
  20. TauSigmaNova's Avatar
    I hear they make decent calls!
    Pfft! Calls!
    Who uses phones to CALL anymore?
    08-14-2012 03:28 PM
  21. cbucz24's Avatar
    Pfft! Calls!
    Lmfao! I've had my evo for 2 weeks an I've made 4 calls.
    AOKP anything
    08-14-2012 03:30 PM
  22. tdm's Avatar
    No disrespect to the devs, but that just seems wasteful. I mean, if one distro kernel binary can drive pretty much all the different x86 pc's in the world, then it must be possible to get one kernel binary to drive different basebands on a single phone model.
    Sure, it takes a bit of time to sort out the differences and make one binary compatible with all of them, but it's totally worth it. Each kernel adds like 3mb to the ROM binary.
    RidDleZ and nitestalkr like this.
    08-14-2012 03:36 PM
  23. tdm's Avatar
    Got a successful CM9 multi-rom install on my VM670. The installer detected the phone baseband and model, and applied patches to the appropriate files. I'll be doing AOKP next, and then updating github and probably pushing out beta3 as a multi-rom.
    I'm also sorting out the thunderc specific stuff in the Quattrimus build tree because the Marquee doesn't like it. Specifically the baseband hack. That's going to get pushed back to RIL.java and conditionally run only if the board name is thunderc. Likewise, the Marquee requires some special code to get 3G running, which will conditionally run only if the board name is sniper.
    PS. The problem with my kernel was the Linaro toolchain. I guess Linaro 4.6 doesn't compile GingerKernel properly, at least by default.
    08-14-2012 03:41 PM
  24. ThatGuyLurkin's Avatar
    Congratz! My main interest is the kernel though. What was the problem with it?
    08-14-2012 03:45 PM
  25. TauSigmaNova's Avatar
    AOKP anything
    Yeah, I've made 2 or 3 calls in the last MONTH!
    I'm probably gonna move to a GNex on TMo's 30 dollar a month plan. Only 100 minutes (though 5GB 4G and Unlimited Text). but hey- who needs minutes!
    08-14-2012 03:51 PM
