01-05-2016 05:35 PM
2,975 ... 8485868788 ...
tools
  1. terthii's Avatar
    Wow, the new site is fantastic. So much easier to find all the bugs and things. Great job!
    08-15-2012 05:15 PM
  2. tmanisawsome's Avatar
    Can someone give me a step by step instruction on how to download this onto my phone
    08-15-2012 05:23 PM
  3. Wheellzz's Avatar
    To those of you using Google Now... Have you gotten the voice interaction to work? I haven't had mine speak back to me. nor have i gotten the mic in the search area to function...am i mis-configuring things somehow...? i'd removed Now and reverted back to regular Voice Search but i see some of you like it, so i'd thought i'd give it another shot. At the time i had been using the mic on the keyboard to get voice input into Now (vs mic in search bar) confounded by its settings... how do "you" have it set up?
    Thanks Everyone.
    08-15-2012 05:46 PM
  4. tdm's Avatar
    I'm still working through how to deal with languages between thunderc and sniper. The thunderc can really only accept English and Spanish or it grows too large. The current quattrimus code simply removed other language files. But the sniper folks have requested other languages, so I need to figure out how to make those coexist.
    In the meantime, I've uploaded a CM9 test ROM to see how the multi-rom thing goes. It's built from a new tree on the server, but should be pretty much the same as the old tree (hopefully). This contains the multi-rom stuff, of course, and also the conditional code for the RIL that does baseband magic for thunderc and 3G magic for sniper.
    You may notice that it's a bit larger than beta2. About half of the difference is due to the multi-rom files, and half due to the inclusion of FR, IT, and DE dictionaries in LatinIME (because I haven't sorted those out yet).
    This is not well tested. Have a backup handy!
    quattrimus-thunderc-cm9-beta3pre.zip
    bigsupersquid likes this.
    08-15-2012 06:05 PM
  5. nitestalkr's Avatar
    I am running aokp, how do you force your apps to your sd-ext3 partition? i have an sd-ext partition on my 32gig sdcard and non of my apps are forcing over like they should. How do i make them? And when i look at my internal space it says i have 173mb free when i should have around 4gb because of my sd-ext.
    Wipe cache and dalvik cache, and your apps should move to the ext partition.
    If you have more than ~20 apps, then they're all on your ext.
    Ignore the storage space read out, iits a minor bug, sometimes it will say you used 367mb out of 178mb and have 154mb of free space.
    Amphetamines is a series of scripts that can be added to the build.prop that increase the speed and performance of your phone.
    sent from my Zom-"Bean'(CM10 JellyBean).
    08-15-2012 06:14 PM
  6. nitestalkr's Avatar
    Read through the thread, its been mentioned several times.
    08-15-2012 06:15 PM
  7. nitestalkr's Avatar
    Thanks Everyone.
    Please refrain from asking such questions when there is a thread dedicated to Google Now.
    Google Now will not be fully functional until all of the needed library files are tracked down, and any other necessary files are edited to support ARMv6 devices.
    08-15-2012 06:18 PM
  8. tmanisawsome's Avatar
    Could you find them for me.
    08-15-2012 06:44 PM
  9. akaEgg's Avatar
    i downloaded it and it worked fine but my phone keeps rebooting. What should i do?
    08-15-2012 06:56 PM
  10. nitestalkr's Avatar
    Goto the very first post, and click either link labled primary, or alternative.
    Download links are there.
    08-15-2012 07:00 PM
  11. kobequintana's Avatar
    Witch 1 are you on CM9 or AOKP
    akaEgg likes this.
    08-15-2012 07:01 PM
  12. nitestalkr's Avatar
    Did you do a clean install?
    Formatting system, data, boot, sdext, cache, and dalvik cache?
    akaEgg likes this.
    08-15-2012 07:01 PM
  13. androidalais's Avatar
    Do a complete wipe, and reflash. It did the same thing to me, you may have a bad md5, if so just re-download the file and reflash.
    akaEgg likes this.
    08-15-2012 07:23 PM
  14. androidalais's Avatar
    Does it make a difference that i partitioned it before flasking AOKP? And will it tell me if they're forced over to the sd card? or will it keep telling me that they're phone only
    08-15-2012 07:25 PM
  15. androidalais's Avatar
    And what is with the app in the app menu in the settings call Unicorn Porn?? and why is it that every time i reboot my phone a window pops up that says "Android is Upgrading" "Optimizing application x of x"
    08-15-2012 07:26 PM
  16. cole2kb's Avatar
    Wallpapers.
    sellers86 likes this.
    08-15-2012 07:29 PM
  17. ThatGuyLurkin's Avatar
    Unicorn Phase Beam.
    nitestalkr likes this.
    08-15-2012 08:29 PM
  18. nitestalkr's Avatar
    They wont move over unless you already have a partition.
    They just automatically move over. There's no clear way other than having a **** ton of apps.
    They will still be classified as "on phone" because the sd-ext script tricks your phone into thinking the ext partition is your internal storage.
    08-15-2012 09:32 PM
  19. nitestalkr's Avatar
    I'm assuming you're using AOKP, and I'm guessing you might have "wipe dalvik cache on boot" checked. Goto settings/rom control/startup tweaks? Or whatever the sub menu is at the very bottom, and disable the dalvik wipe on boot.
    08-15-2012 09:35 PM
  20. tmanisawsome's Avatar
    How do I flash my phone and fill the gapps and stuff like that.
    08-15-2012 10:25 PM
  21. kobequintana's Avatar
    http://forums.androidcentral.com/sho...d.php?t=108282
    [HOW-TO] Simplified Root + Recovery + Custom ROM
    That should explain things
    08-15-2012 10:57 PM
  22. sellers86's Avatar
    If you dont know how to flash a rom DO NOT flash this. Flash something like mirage, get the feel for modding and come back.
    inceyet, nitestalkr and skealoha86 like this.
    08-15-2012 10:59 PM
  23. tmanisawsome's Avatar
    Do I need to root my phone
    08-15-2012 11:29 PM
  24. ThatGuyLurkin's Avatar
    Yes.
    08-15-2012 11:40 PM
  25. tmanisawsome's Avatar
    Can someone give me the download links to ics root and ics recovery image.
    08-15-2012 11:41 PM
