01-05-2016 04:35 PM
2,975 ... 8586878889 ...
tools
  1. tmanisawsome's Avatar
    Yes.
    Do you need ics root like gingerbreak
    08-15-2012 10:49 PM
  2. kobequintana's Avatar
    Can someone give me the download links to ics root and ics recovery image.
    Read the link I posted it has root recovery image and a custom ROM
    inceyet and tdm like this.
    08-15-2012 10:50 PM
  3. terthii's Avatar
    Installed beta2 today. I am VERY impressed! Running at 480/600mhz and my phone had never been so smooth! Back in alpha, I had reboot and overheating issues but those appear to be nonexistent. Coming from Mirage, the battery doesn't seem to be quite as good, but as long as it isn't too big of an issue, it'll be my daily! Fantastic job, tdm!
    tdm likes this.
    08-15-2012 10:50 PM
  4. tmanisawsome's Avatar
    I want ics not gingerbread
    08-15-2012 10:53 PM
  5. kobequintana's Avatar
    Are you on stock rom
    08-15-2012 10:54 PM
  6. tmanisawsome's Avatar
    Yea
    08-15-2012 10:57 PM
  7. kobequintana's Avatar
    Yea
    OK than that thread will work that's how I rooted and got my recover etc
    08-15-2012 10:58 PM
  8. tmanisawsome's Avatar
    OK thanks
    08-15-2012 11:04 PM
  9. sellers86's Avatar
    Please take the talk about how to root to the rooting thread.
    Sent from my VM670 using Tapatalk
    nitestalkr and inceyet like this.
    08-15-2012 11:05 PM
  10. tmanisawsome's Avatar
    For the flash custom rom should I use the ics at getquattrimus.com
    08-15-2012 11:21 PM
  11. brotherswing's Avatar
    Yes, but you seem to be jumping in at the deep end. From all the questions you're asking, you really should start more slowly.
    sent from the hip.
    08-15-2012 11:28 PM
  12. nitestalkr's Avatar
    Stick to everything in that guide, and when you have decent experience with flashing various roms and have an understanding of what is involved in android development, then you will be able to safely flash this rom.
    ICS is still under development, so there are still several things wrong with it, stick to gingerbread for a while first.
    sent from my Zom-"Bean'(CM10 JellyBean).
    08-15-2012 11:29 PM
  13. kobequintana's Avatar
    OK like sellers86 said let go back to the quttrimus talk any mor questions could be in a new thread (sorry if that sounds bad)
    inceyet, nitestalkr and sellers86 like this.
    08-15-2012 11:37 PM
  14. kirurus's Avatar
    I'm still working through how to deal with languages between thunderc and sniper. The thunderc can really only accept English and Spanish or it grows too large. The current quattrimus code simply removed other language files. But the sniper folks have requested other languages, so I need to figure out how to make those coexist.
    In the meantime, I've uploaded a CM9 test ROM to see how the multi-rom thing goes. It's built from a new tree on the server, but should be pretty much the same as the old tree (hopefully). This contains the multi-rom stuff, of course, and also the conditional code for the RIL that does baseband magic for thunderc and 3G magic for sniper.
    You may notice that it's a bit larger than beta2. About half of the difference is due to the multi-rom files, and half due to the inclusion of FR, IT, and DE dictionaries in LatinIME (because I haven't sorted those out yet).
    This is not well tested. Have a backup handy!
    quattrimus-thunderc-cm9-beta3pre.zip
    Flashed fine on my V. Nice work tdm.
    New Kernel?
    tdm likes this.
    08-16-2012 12:14 AM
  15. whatthefreak's Avatar
    Did anyone else experience browser crashes in beta1? I'm wondering if that was at least partially fixed in beta2.
    Now I'm thinking I can use an alternative like opera. Hmm.
    08-16-2012 12:56 AM
  16. Rayz321's Avatar
    Hey what processor settings do you guys recommend for this rom?
    08-16-2012 01:06 AM
  17. kobequintana's Avatar
    Depends
    CM9: 480/600 INTERACTIVEX
    AOKP: 480/7XX SAVAGEZEN
    The XX are the rest of the number you choose in the 700s
    08-16-2012 01:19 AM
  18. Skygen's Avatar
    Hey tdm! Nice work on the ROM. Been using Beta 2 for the last weekish now, updated from beta pre3 lol. Glad to see all the hard work being put into this, I'm sure a lot of us appreciate it, myself included.
    I do have a curious question for you though, or anyone else willing. How hard would it be to patch the wpa_supplicant to be able to see Adhoc wifi networks? I think it would be just a little added bonus to the rom, so I wouldn't fret over it.
    Here's a link to the page with the patch itself: szym.net Ad-hoc Wifi in Android
    I would attempt to compile it myself, as it would be useful for me, but I'm lost on how to start. Sorry, new here lol. In reality I'm trying to compile one for my tablet, so I can use my phone as a hotspot for it, but as mentioned, i'm a bit lost.
    tdm likes this.
    08-16-2012 03:53 AM
  19. androidalais's Avatar
    My phone has been running warm, any particular reason?
    08-16-2012 06:09 AM
  20. nitestalkr's Avatar
    You're either overclocked too high, display is on too long, or your charger is producing an abnormally higher voltage.
    08-16-2012 06:35 AM
  21. jayleekay's Avatar
    Seriously. It's making my blood boil.
    sellers86 likes this.
    08-16-2012 09:24 AM
  22. terthii's Avatar
    Using beta2 and it's default messaging program. I can't seem to get the SMS notifications to vibrate. Anyone else?
    08-16-2012 09:42 AM
  23. anthonycr's Avatar
    Messaging app>>settings>>notifications>>vibrate
    You have to have it enabled in both messaging settings and global settings
    08-16-2012 09:52 AM
  24. Rayz321's Avatar
    @tdm hey I'm going later to buy an lg optimus T. I don't plan on activating it or anything like that but just for something at home with wifi. If I flashed your rom on it could it have any problems?
    Depends
    Thank you, is there a reason that you recommend setting it to 480 instead of lower?
    08-16-2012 11:18 AM
  25. sellers86's Avatar
    For the first part, the OV version would probably have issues. as for the second, anything below 480 drains your battery and is pretty much worthless. lol
    08-16-2012 11:29 AM
