01-05-2016 05:35 PM
2,975 ... 8687888990 ...
tools
  1. kirurus's Avatar
    Hey tdm! Nice work on the ROM. Been using Beta 2 for the last weekish now, updated from beta pre3 lol. Glad to see all the hard work being put into this, I'm sure a lot of us appreciate it, myself included.
    I do have a curious question for you though, or anyone else willing. How hard would it be to patch the wpa_supplicant to be able to see Adhoc wifi networks? I think it would be just a little added bonus to the rom, so I wouldn't fret over it.
    Here's a link to the page with the patch itself: szym.net Ad-hoc Wifi in Android
    I would attempt to compile it myself, as it would be useful for me, but I'm lost on how to start. Sorry, new here lol. In reality I'm trying to compile one for my tablet, so I can use my phone as a hotspot for it, but as mentioned, i'm a bit lost.
    My V with quattrimus CM9 flashed can already pick up Ad-hoc. I use it at home.
    08-16-2012 12:39 PM
  2. Rudeco's Avatar
    Anyone else have problems on tango or oovoo when their in a video chat and plug headphones in..... the mic on the phone won't work.
    08-16-2012 01:00 PM
  3. terthii's Avatar
    Messaging app>>settings>>notifications>>vibrate
    You have to have it enabled in both messaging settings and global settings
    Yeah, I did that. In the messaging I put it to vibrate always, and have tried multiple vibration patterns. I also have it to globally vibrate through using the sound control toggle in the notification menu (sound and vibrate enabled). Other UI elements use the vibrate just fine, just not my SMS.
    08-16-2012 01:33 PM
  4. terthii's Avatar
    Another bug I've found is that the display will just randomly die. The only way to get it to turn back on is to pull the battery.
    08-16-2012 01:44 PM
  5. terthii's Avatar
    This bug is present in IHO (Gingerbread) on calls. This might be something similar.
    08-16-2012 01:47 PM
  6. drew_t's Avatar
    Anyone else getting an error message about "insufficient storage available" when you try to update Google Maps? It's downloading 55% of a 6.25 mb file, then says it's updating, then displays the error message.
    Seems from the comments in the Play Store that a lot of people are having various problems with this update.
    08-16-2012 02:23 PM
  7. anthonycr's Avatar
    Maybe your over clock is too high... or your phone is dying
    08-16-2012 02:27 PM
  8. terthii's Avatar
    I just updated mine with no problem.
    08-16-2012 02:27 PM
  9. terthii's Avatar
    Nope. I'm at 480/600mhz. And I never had this problem before on any other ROM. It's almost like the ROM dies though. The buttons won't light up or anything either. It isn't frequent, but annoying nonetheless.
    08-16-2012 02:28 PM
  10. tcrider84's Avatar
    @tdm hey I'm going later to buy an lg optimus T. I don't plan on activating it or anything like that but just for something at home with wifi. If I flashed your rom on it could it have any problems?
    Thank you, is there a reason that you recommend setting it to 480 instead of lower?
    usually with anything lower than 480 i have constant freezes/crashes
    08-16-2012 02:43 PM
  11. androidalais's Avatar
    You're either overclocked too high, display is on too long, or your charger is producing an abnormally higher voltage.
    sent from my Zom-"Bean'(CM10 JellyBean).
    Not overclocked, but I have the governer set to conservative, and I'm using my kindle fire charger, hasnt ran hot since I flashed AOKP
    08-16-2012 02:55 PM
  12. kobequintana's Avatar
    Do you have an sd ext
    Sent from my VM670 using Android Central Forums
    08-16-2012 03:03 PM
  13. jayleekay's Avatar
    I've been getting "insufficient space" errors as well. I fix it by going into Manage Apps. You'll notice at the bottom that you are indead low on space. Wait a few seconds, it will go down. Wait a few more seconds and it will go down even further. You may have to click through the tabs. Hit home key, google play, then install your app. I have at least a gb of sd-ext fyi.
    08-16-2012 03:11 PM
  14. xaphoo's Avatar
    After running Quattrimus CM9 Beta 2 on VM670 for a while, I switched to Beta 2 AOKP. It seems ok (though CM9 may be a more refined experience), but for some reason I can't reboot to recovery from within the ROM or even turn it off. In fact, holding down the power button always just RESETS the machine, instead of giving me the option to turn it off, reboot, reboot into recovery, etc...
    08-16-2012 03:33 PM
  15. kobequintana's Avatar
    Its a known issue no work around (I don't think their is)
    08-16-2012 03:37 PM
  16. jcf41's Avatar
    I have the exact same problem. Running CM9 and 480/600 Performance. Have also tried InteractiveX and Savageden and same issue. Seems to happen most during phone calls. I just purchased my V in June.
    08-16-2012 03:40 PM
  17. terthii's Avatar
    I solved my problem of no vibration with the default messaging app. For anyone that has the same issue, here's how I fixed it:
    1) First enable vibration in the app and globally (duh!)
    2) Download PopUp 7 Free from the Play Store
    3) Configure it to notify with vibration (don't bother messing with the settings, your not going to keep the app, unless you want to)
    4) Receive a text (you can text yourself)
    5) (Optional) Uninstall PopUp 7 Free, and you should get vibration in the default messaging app!
    08-16-2012 03:41 PM
  18. terthii's Avatar
    Hmm. I haven't made any phone calls yet using this ROM; I mostly text. Does it happen often? Mine happened at Starbucks with it being idle in my pocket, and when updating Google Maps (although the app was fully updated, nothing was screwed up when I rebooted).
    EDIT: My dad just called me and it worked just fine.
    08-16-2012 03:45 PM
  19. jcf41's Avatar
    Happened just yesterday after I left a message for someone. Doesn't happen all the time, but noticed it a couple of times using the phone. Has also happened randomly like your examples above.
    08-16-2012 04:47 PM
  20. tmanrules's Avatar
    I downloaded the file on http://getquattrimus.com/ but comes up with a folder with 3 files which one do I put in to my phone.
    http://androidz.jimdo.com/lg-optimus...-lg-optimus-v/ What file do i need to change to put ics on my lg optimus v.
    08-16-2012 05:24 PM
  21. terthii's Avatar
    Hmm, strange. I really have no idea what would be the problem. You aren't overclocked right?
    08-16-2012 05:29 PM
  22. grantbob's Avatar
    So if you want to reboot into recovery you have to pull the battery?
    08-16-2012 06:00 PM
  23. kobequintana's Avatar
    I don't know I only tried AOKP once
    08-16-2012 06:03 PM
  24. drew_t's Avatar
    Yes, I have one, and I haven't run into any memory problems before this.
    After making the post, I tried a couple more times to get Maps to update, and eventually it did. Not sure what the real issue was. AFAIK I have plenty of memory, and a couple other apps have updated since then without triggering any error messages.
    I've noticed before that it does that . Not sure what that is really demonstrating - is stuff actually being moved as that's happening, or is it just refreshing a calculation, or ? And does the phone's OS really care if stuff is in the internal memory or not, as long as it knows where it is? And should it have any effect on the app update process?
    08-16-2012 07:28 PM
  25. terthii's Avatar
    Just a heads up- Google Ears, Google's Shazam-like widget implemented in Jelly Bean, is now up for grabs on ICS. It appears to be fully functional and you just have to install an apk. It's over at XDA, if anyone is interested (I don't think we can post links to other sites, right?).
    EDIT: http://forum.xda-developers.com/show....php?t=1742652
    08-16-2012 07:28 PM
