01-05-2016 04:35 PM
2,975 ... 7891011 ...
tools
  1. RazzMaTazz's Avatar
    Anybody know if SprintTV works on Quattrimus? If not, is it likely to ever work?
    07-06-2012 11:52 AM
  2. inceyet's Avatar
    Well aokp is a BEAST!!! That's after o had to reflash it...did a dirty flash and it would not stop rr over and over sooo did a complete wipe reinstall and uno that was the prob. Haven't messed with oc but that's next looks like the avg is 480/784 . TDM and the kraven y'all killed it with these roms
    tdm and Badboytoast like this.
    07-06-2012 12:05 PM
  3. anon406695's Avatar
    I'm not too sure if this is a bug but....
    When I touch my screen, my physical buttons light up (menu, home, etc). If I lift my finger off the screen, after a few seconds, they go off. This has always happened on every build of Quattrimus I've tried.
    07-06-2012 12:07 PM
  4. cmerlyn's Avatar
    Every time I flash a nightly I lose an app or two. BeWeather Pro in particular disappears. When I try to restore it from TiBu, it tells me it will overwrite an existing app, and then fails to install it.
    I use the Prep to Upgrade prior to flashing.
    Any suggestions?
    Thanks
    [edit] Flashing gapps again solved the problem. Realized that when PlayStore wouldn't open. I guess the nightlies mess up some of the gapps stuff.
    07-06-2012 12:09 PM
  5. reaper420's Avatar
    I didn't even notice until i read your post
    07-06-2012 12:14 PM
  6. sdxben's Avatar
    Any suggestions?
    Thanks
    Try rebooting once, this happens to me on occasion and when I reboot -"android upgrades" giving me that app back.
    cmerlyn likes this.
    07-06-2012 12:15 PM
  7. chuckconnors's Avatar
    As others have said, and what worked for me was to:
    1) backup apps with titanium backup
    2) backup the data from your sd card to your computer
    4) repartition sd card in recovery (will erase all data on sd card, so make sure to back up)
    5) move files back to sd card from computer
    6) restore apps using titanium backup
    It's a pain and a half, but this was the only method that was able to fix this issue reliably for me.
    I was having the invalid package issue too and this seems to have fixed it! Thank you so much!
    A couple questions though: It seems like Titanium Backup tries to restore apps (maybe only some of them) to internal instead of /sd-ext . Is there a way to force it to restore to /sd-ext? Also, how can you list what is on internal memory? Finally, why do some apps show Move to SD or Move to Phone while others don't have this option available?
    07-06-2012 12:17 PM
  8. cmerlyn's Avatar
    Rebooting didn't help. Flashing gapps got it back though.
    Thanks anyway, all help always appreciated.
    07-06-2012 12:20 PM
  9. ItsMoo's Avatar
    I'm finding that I have to reflash gapps even after flashing the nightly, otherwise the Play Store won't work.
    Also, I'm not sure if this is an ICS issue, but whenever I install a new app, it tries to place a widget on the desktop and gives me "not enough space on this home screen" not a big deal, just fyi.
    Sent from my Quattrimus ICS Optimus V
    07-06-2012 12:32 PM
  10. drm1992's Avatar
    Any luck with the Facebook app?
    07-06-2012 12:38 PM
  11. tdm's Avatar
    Taking a new approach to the kernel. I noticed the P700 uses the msm7x27 and comes with ICS, so I'm using that for a base to start with. Looks like much less work than my previous approach, but still not easy by any means.
    07-06-2012 01:02 PM
  12. ryder815's Avatar
    do i have to reinstall the rom too
    07-06-2012 01:06 PM
  13. inceyet's Avatar
    Don't know if this has been addressed at work can't look through the tread but phone reboot when listening to music and try to adjust phone settings
    07-06-2012 01:18 PM
  14. sellers86's Avatar
    Is this for gingerkenel? and what changes would it have?
    07-06-2012 01:25 PM
  15. kcls's Avatar
    Hey tdm, did you ever get the chance to look at those graphics? Anything you would want me to change?
    07-06-2012 01:32 PM
  16. coolbryan22's Avatar
    I have been having that problem since cm9 pre beta 3 u r the only person I have seen post anything about the issue. I posted on the alpha thread and it went unanswered. I'm now taking screen shots of the log after the freeze and I believe it said error 624 but I'm not sure on the error number. Next time it happens take a screen shot and post it. Ima post the few screenshots I have after the next YouTube freeze
    I posted about it as well... noticed that other apps where you watch videos freeze up the same way after 7-20 minutes too
    07-06-2012 01:34 PM
  17. ryder815's Avatar
    i tried to partition my sd card and its says i can only do it up 4gb and i have an 8 gb card
    07-06-2012 01:47 PM
  18. tdm's Avatar
    It's a real ICS (3.0.8) kernel. Changes would be ... updating to version 3.0.8.
    sellers86 and inceyet like this.
    07-06-2012 01:47 PM
  19. tdm's Avatar
    I did thanks. I am pretty slammed at the moment, but yeah, they look great.
    kcls and jobotslash like this.
    07-06-2012 01:48 PM
  20. tdm's Avatar
    1gb should be plenty for a couple hundred apps.
    I've heard there are issues if you try to go above 2gb but I can't confirm, I never tried.
    ryder815 likes this.
    07-06-2012 01:49 PM
  21. HurrrDurrrDURP's Avatar
    *Fap Fap Fap Fap Fap Fap Fap*
    What kind of changes are needed to make for the kernel to run on our phones? I'm guessing it has a lot of Arm7 only Assembly code?
    07-06-2012 02:04 PM
  22. tdm's Avatar
    Support for different hardware between the P700 and our phones. Off the top of my head:
    * LG specific stuff related to baseband, battery, and such.
    * Touchscreen drivers for Novatek and Hitachi screens.
    * BCM4325 driver for wifi.
    * MTD and yaffs2.
    That's the bulk of it, but there may be a bit more.
    I'm hoping that most of these can be copied from gingerkernel and tweaked. In fact that's what I'm doing right now...
    07-06-2012 02:22 PM
  23. sellers86's Avatar
    sorry tdm, i had to ditch aokp... It was running great yesterday no reboots no anything. then today... well today ive had about 8 reboots in the last 15 minutes. Maybe the memory management stuff? thanks for the hard work though.
    07-06-2012 02:24 PM
  24. sellers86's Avatar
    * MTD and yaffs2.
    good luck!
    07-06-2012 02:26 PM
  25. ryder815's Avatar
    thanks for the help it worked out great this rom is bad a$$
    tdm likes this.
    07-06-2012 02:27 PM
