01-05-2016 05:35 PM
2,975 ... 9495969798 ...
tools
  1. drew_t's Avatar
    I have the same issue. If I leave my phone sitting around for a couple of house the wifi connection gets dropped and doesn't reconnect when I wake it back up. A simple toggle of the wifi from the notification bar gets it to reconnect.
    I had that issue when I was on Backside, but since changing to Quattrimus CM9, it hasn't happened at all.
    08-26-2012 08:56 PM
  2. brotherswing's Avatar
    Rotation fixes the status bar time display, but the "Ice Cream Sandwich Clock" widget I have on my home screen doesn't pick up the correction. Only the clock sync app (which I have set to sync every 15 minutes since every 30 seconds seems excessive) works on it.
    Ah...I use Fancy Widgets, that seems to stay in closer sync.
    sent from here to there...
    08-27-2012 12:09 PM
  3. dingermtb's Avatar
    Been getting a new market error now. When trying to download free apps, i get "error processing purchase (DF-BPA-09)" That's for free apps, not paid apps. Anybody else getting this? Also, tried clearing market cache and data, then in recovery, cleared cache and dalvik cache.
    Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
    08-27-2012 12:27 PM
  4. brotherswing's Avatar
    I got that. Clear the data for Google Services Framework. You might need to reflash gapps afterwards. When it happened to me (yesterday) I got it fixed, but the calendar went missing.
    dingermtb likes this.
    08-27-2012 12:46 PM
  5. dingermtb's Avatar
    Worked clearing Google Services Framework, then rebooting. Thanks
    08-27-2012 01:10 PM
  6. johnh02's Avatar
    Is there anyway to get beats audio on this rom?
    Sent from my LG-VM670 using Xparent ICS Blue Tapatalk 2
    08-27-2012 06:00 PM
  7. dingermtb's Avatar
    I used the app on the market (ROOT) Beats Audio Installer. I use it with AOKP and, at least on my phone, it does make a difference
    johnh02 likes this.
    08-27-2012 07:29 PM
  8. johnh02's Avatar
    I heard someone say it doesn't work. I might try it though does the beats logo pop up while your listening to music?
    08-27-2012 07:42 PM
  9. HurrrDurrrDURP's Avatar
    tdm, will you be releasing the beta 3 build with cyanogen mod stable?
    08-27-2012 10:37 PM
  10. jonny5449's Avatar
    Love this error
    Jkjk
    Uninstall updates on play store and let it re update it will be all good that's what I always di
    Sent from my LG-LS670 using Tapatalk 2
    08-27-2012 11:07 PM
  11. dingermtb's Avatar
    Notification icon doesn't pop up, but my music sounds alot better. I'm using it with Power Amp.
    johnh02 likes this.
    08-28-2012 12:12 AM
  12. androidalais's Avatar
    Hey tdm, whens beta3 gonna come out?
    Sent from my hot ice cream sandwich
    johnh02 likes this.
    08-28-2012 07:10 AM
  13. jonny5449's Avatar
    I'm quoting the wise drew
    Patience is virtue
    glarepate likes this.
    08-28-2012 07:21 AM
  14. brotherswing's Avatar
    Every time you ask for an eta, Santa kicks a puppy.
    Pomman, glarepate, johnh02 and 1 others like this.
    08-28-2012 07:57 AM
  15. jonny5449's Avatar
    :what:
    08-28-2012 07:59 AM
  16. JesMFN's Avatar
    Does anyone know where to find the proper gapps for cm9 or aopk mirror 4 for virgin mobile optimus v?
    08-28-2012 09:29 AM
  17. JesMFN's Avatar
    Also does everything work well with virginmobiles top up system? Do monthly payment s register properly with the phone?
    08-28-2012 09:51 AM
  18. nerdmastax's Avatar
    the top up system is just a website, you could also dial *86
    08-28-2012 10:25 AM
  19. ThatGuyLurkin's Avatar
    Reminds me of Futurama. Every Christmas, Santa flies around and kills people saying " YOU'VE ALL BEEN NAUGHTY ".....
    Anyways, TDMs on vacation, try Bobz rom if you want a more updated rom until tdm drops what he's working on.
    08-28-2012 11:07 AM
  20. Pomman's Avatar
    Bob Rom is good all about. Only like all of them missing key sound. I flash is same time beats audio and sound bloom/!\
    Sent from my LG-VM670 using Tapatalk 2 Beta-5
    08-28-2012 11:13 AM
  21. JesMFN's Avatar
    Can anyone please upload gapps and link them? I cant find them anywhere are they inval not up to date or something?
    08-28-2012 11:55 AM
  22. ZackVortex's Avatar
    Just search Gapps on google I always do that
    08-28-2012 12:26 PM
  23. Pomman's Avatar
    http://getquattrimus.com/roms/quattrimus/
    Sent from my Type-R Tapatalk 2
    tdm likes this.
    08-28-2012 12:58 PM
  24. clodfelterac's Avatar
    https://docs.google.com/uc?authuser=...xport=download
    jobotslash likes this.
    08-28-2012 02:07 PM
  25. lickity split's Avatar
    I use the Beautiful Widgets clock widget and it stays in perfect time for me.
    08-28-2012 02:26 PM
