01-05-2016 05:35 PM
2,975 ... 96979899100 ...
tools
  1. ThatGuyLurkin's Avatar
    Does a SD partition make the system any faster?
    08-30-2012 01:10 PM
  2. HurrrDurrrDURP's Avatar
    That's old code and it's already in there.
    Not to sound like a jerk, but where? I mean it was turned on in the config.
    BuggerZ and terthii like this.
    08-30-2012 02:36 PM
  3. strabo231's Avatar
    depends on how much you put on it. Some say yes, some say no. I'm a huge yes though. I had a lot of space and performance issues straighten out after I added one
    08-30-2012 06:25 PM
  4. vawlk's Avatar
    Hmm. I guess I can understand that. But the reason I don't get it is because I have at least 500-600MB free on my sd-ext partition (just checked), but internal storage lists 40MB free left.
    /data/app and /data/dalvik-cache is moved to the sd-ext but /data/data isn't and that still fills up with a bunch of libraries and app storage. I have about 90 apps installed and have 32mb free even though I have 923mb left on my sd-ext.
    So there is still a limit.
    BuggerZ likes this.
    08-30-2012 08:49 PM
  5. BuggerZ's Avatar
    We should move /data/data to sd-ext in the ROM then... I think that might solve our problems then. Because internal space still dwindles down quickly, though not quite as quickly as with apk's on internal, but still...
    08-30-2012 11:34 PM
  6. tdm's Avatar
    Yeah I can do that .. Might make it an optional thing.
    08-30-2012 11:51 PM
  7. kcls's Avatar
    Would that possibly solve the insufficient space error on the play store? Because I have noticed it has no problem updating small apps, but big apps like Google Maps refuse to update.
    Tapatalk from my Optimus V
    08-31-2012 01:00 AM
  8. flapjack.fiasco's Avatar
    That means Beta 3! Squeeeeee!
    BuggerZ likes this.
    08-31-2012 01:08 AM
  9. brotherswing's Avatar
    Perhaps an optional zip to flash if the end user wants data2sd. Unless you use something like Aroma where the option could be selected during install.
    sent from here to there...
    08-31-2012 10:33 AM
  10. BuggerZ's Avatar
    Ya, of course. I would expect it to be optional. Thanks.
    Edit: I don't think /data/data is my culprit though. It's only 34MB. UNLESS that 34MB would cause the memory to go down that fast that is.. Maybe /data/app (130MB) + /data/data (34MB) + /data/dalvik-cache (116MB) cause everything to really add up.
    Edit 2: I installed a app called diskusage. This shows me what's going on here. /data/data lists 129MB with a free space of 43MB left.... That's exactly what my internal storage lists as left. So ya, that does seem to be the culprit after all. Ignore the above edit then. Moving /data/data to sd-ext will really solve a lot of 'out of space' issues for me and others. Thanks!
    flapjack.fiasco and terthii like this.
    08-31-2012 11:43 AM
  11. androidalais's Avatar
    I've noticed that the fact that the phone doesn't fully enter deep sleep mode causes my phone to run about twenty degrees higher than normal. On stock and 2.3 i ran at about 65, with quattrimus i run at 79-85. With bobz since the deep sleep fix it runs at about 70. Has anybody else noticed this?
    08-31-2012 05:01 PM
  12. inceyet's Avatar
    @tdm gotta simple question well more curious than anything in the UI btw I'm on aokp beta2 is there anyway to make it possible to change the color of the circle mod icon cause I'm using acr's afterburner and I would like to be able to change the color of the circle mod cause its blue . Well I was just wondering its really no big deal just more for my self thanks for all the hard work
    Sent from a humblebeast
    08-31-2012 06:24 PM
  13. brotherswing's Avatar
    Afterburner could be modified to display the circle style battery indicator, I'll talk to Anthony about it. I'm working on two roms right now plus I got married today, otherwise I'd offer to do it myself.
    08-31-2012 08:34 PM
  14. inceyet's Avatar
    Real well Congrats may you have a blessed marriage . Word good looking out definitely appreciate that
    brotherswing likes this.
    08-31-2012 08:38 PM
  15. flapjack.fiasco's Avatar
    Congratulations!
    08-31-2012 10:38 PM
  16. cole2kb's Avatar
    What the hell are you doing on the forums right now then? lol. Congrats, man
    09-01-2012 12:51 AM
  17. Zhara's Avatar
    Lol that was my first thought too. I'm all about some AC, but there are certain days where it's banned, and my wedding day would have to be one of them
    Anyway, congratulations, brotherswing!
    Sent from my Epic 4G Touch
    benslgdroid and brotherswing like this.
    09-01-2012 01:11 AM
  18. ThatGuyLurkin's Avatar
    Congratulations!
    09-01-2012 01:49 AM
  19. sdxben's Avatar
    I am currently on Beta 2 and have the oddest problem.. anytime one of my friends sends me a text using their iPhone as a group text - -- The text is blank on my phone with only the timestamp. Any suggestions?
    09-01-2012 07:08 AM
  20. brotherswing's Avatar
    Hey, if she fires up Facebook, I fire up Tapatalk. We understand each other.
    tvall likes this.
    09-01-2012 03:29 PM
  21. jonny5449's Avatar
    Congrats bro
    Sent from my LG-LS670 using Tapatalk 2
    09-01-2012 03:35 PM
  22. Encerspay45's Avatar
    brotherswing is married! Next time, on "As Quattrimus Turns"...
    09-01-2012 04:07 PM
  23. thewraith420's Avatar
    What's the latest nightly guys? Only one of the mirrors shows them and it's 7-21 is that the the latest?
    Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.3 on LS670ZVJ Baseband
    09-01-2012 04:34 PM
  24. LG_VM670's Avatar
    No I believe betta 2 was the last unless you count the test one tdm uploaded like a month ago witch would be betta 3
    thewraith420 likes this.
    09-01-2012 04:37 PM
  25. Phatninja55's Avatar
    Has anyone else had the problem of the clock not updating? Its 6:06 and it said 5:56.
    Sent from my LG-VM670 running Quattrimus via TapaTalk2
    09-01-2012 07:06 PM
