01-05-2016 04:35 PM
2,975 ... 979899100101 ...
tools
  1. ZackVortex's Avatar
    Has anyone else had the problem of the clock not updating? Its 6:06 and it said 5:56.
    Sent from my LG-VM670 running Quattrimus via TapaTalk2
    Wow I thought it was me because I think that happens to me on jellybean to unless I was on ICS thinking I was on jb XD
    09-01-2012 06:18 PM
  2. sellers86's Avatar
    This is a know problem.
    anthonycr and Ryuk6666 like this.
    09-01-2012 06:55 PM
  3. conanthereaper's Avatar
    Just back out and go back in the app. I've had this problem for a while and this has worked for me.
    09-01-2012 11:25 PM
  4. brotherswing's Avatar
    Just rotate the screen, it'll update.
    sent from here to there...
    09-01-2012 11:31 PM
  5. bennettg's Avatar
    Will the new kernel allow for infrastructure mode tethering? I tried bobz but it doesn't allow for infrastructure tethering
    09-02-2012 05:59 AM
  6. ZackVortex's Avatar
    Yeah it should the ics and jb roms don't have tethering yet
    Sent from my VM670 using Android Central Forums
    LG_VM670 likes this.
    09-02-2012 06:12 AM
  7. HurrrDurrrDURP's Avatar
    How is the new kernel coming along?
    And I thought this was a dead project?
    09-03-2012 12:38 PM
  8. Rudeco's Avatar
    Please release new kernel! Lol
    I see BobZ just released 9.0.1, but I need offline charging and only TDMs ICS has it.
    09-03-2012 01:31 PM
  9. bennettg's Avatar
    Bobz doesn't have infrastructure tethering even with his new kernel
    09-03-2012 07:59 PM
  10. ZackVortex's Avatar
    Tried the pre beta3 its awesome
    Great work tdm good luck with the new kernel
    tdm likes this.
    09-03-2012 08:41 PM
  11. carloswii5's Avatar
    Pre beta?
    Sent from my MIUI (;
    09-03-2012 09:10 PM
  12. clodfelterac's Avatar
    @tdm--- quick question... trying to view android_device_lge_VM670/ android_device_lge_thunderc-common on your git but nothing is there, just headers... have you moved the files since incorporating the multi rom installer?...
    09-03-2012 09:12 PM
  13. ZackVortex's Avatar
    I'm still working through how to deal with languages between thunderc and sniper. The thunderc can really only accept English and Spanish or it grows too large. The current quattrimus code simply removed other language files. But the sniper folks have requested other languages, so I need to figure out how to make those coexist.
    In the meantime, I've uploaded a CM9 test ROM to see how the multi-rom thing goes. It's built from a new tree on the server, but should be pretty much the same as the old tree (hopefully). This contains the multi-rom stuff, of course, and also the conditional code for the RIL that does baseband magic for thunderc and 3G magic for sniper.
    You may notice that it's a bit larger than beta2. About half of the difference is due to the multi-rom files, and half due to the inclusion of FR, IT, and DE dictionaries in LatinIME (because I haven't sorted those out yet).
    This is not well tested. Have a backup handy!
    quattrimus-thunderc-cm9-beta3pre.zip
    This one
    jonny5449, flapjack.fiasco and tdm like this.
    09-03-2012 09:12 PM
  14. tdm's Avatar
    Hmm, well, first, make sure you are looking at the correct account. I switched from github.com/thunderc to github.com/thebigq when I started making ROMs for the sniper (and anticipate gelato to follow Real Soon Now). The current code is all there. I need to clear out the old account to eliminate confusion. The repos are named cm_device_lge_VM670, cm_device_lge_thunderc, and etc. Note the first component is the project (cm or aokp). And there is no -common after thunderc anymore because thunderc is a buildable target in the multi-rom world order. Finally note that the manifests should be good but I can't guarantee it. I tried switching from keeping a local_manifest.xml to a full manifest repo, but found that frustrating on several levels. So I'll be switching back.
    09-03-2012 10:32 PM
  15. ZackVortex's Avatar
    Lmfao sorry for this post but
    Tdm is the calculator working because I'm helping my friend do her homework and I keep getting a decimal and I'm thinking uts e but knowing this is a work in progress I though I might ask
    ThatGuyLurkin likes this.
    09-04-2012 10:43 PM
  16. tdm's Avatar
    It works great, this is an arm cpu not a pentium.
    09-04-2012 10:55 PM
  17. ZackVortex's Avatar
    OK thank you very much
    09-04-2012 10:56 PM
  18. nerdmastax's Avatar
    im trying to build the aokp version and keep getting stuck at 309/312 on repo sync...
    09-04-2012 11:46 PM
  19. BlairFam07's Avatar
    The Pre-beta3 has been my daily since you released it and its great the only time I ever freeze is browsing the play store. everything else is great. Love your work TDM
    Encerspay45, Pomman and tdm like this.
    09-05-2012 10:30 AM
  20. jonny5449's Avatar
    Sorry tdm what was changed in pre beta 3?
    Sent from my LG-LS670 using Tapatalk 2
    09-05-2012 04:31 PM
  21. inceyet's Avatar
    I do believe that's just the multi rom
    Sent from a humblebeast
    09-05-2012 05:06 PM
  22. KidFr3sH's Avatar
    Where can I find the pre beta ?
    09-05-2012 05:14 PM
  23. thewraith420's Avatar
    In a quote about 10 posts ago :-)
    Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.3 on LS670ZVJ Baseband
    09-05-2012 05:16 PM
  24. androidalais's Avatar
    What is the difference between cm9 and aosp?
    Sent from my Kindle Fire using Android Central Forums
    09-05-2012 06:27 PM
  25. jonny5449's Avatar
    Aosp is more of a stock feel of ics closest to ics update as we will get
    ZackVortex likes this.
    09-05-2012 06:42 PM
