inceyet
How do I check it? How do I manage it? It's driving me crazy.
I use es file explorer
Camera is under sounds menu on both roms.
I just discovered that AOKP doesn't have Apollo (or any other music player) by default, and Apollo isn't available in Market. Any suggestions for a music player that works, well, about like the default Android music player (i.e., Apollo)? Or how to acquire Apollo?
Last I checked, most of the fully-featured players (e.g., Winamp et al) are overloaded with extra junk I won't need (including but not limited to ads, annoying trial periods, or crippleware), and DeadBeef is as bad on Android as it is my laptop (nonstandard commands and impractical issues with playlists).
I downloaded an official AOKP build (for the p990) and, as strange as it may seem, it appears they don't include a music player. I found the commit in github that removed it, so it was intentional. Also found this thread which verifies that this is intentional.
I could build one, but space is tight already (I had to remove SwagPapers to make room for gapps, which made me sad -- it ruins part of the AOKP experience). Better to install your own preferred player so that it doesn't eat more space in /system.
Hey tdm, just wanted to drop by and say thanks for all of the amazing work, Quattrimus for the optimus has come a very VERY far way in less than a few months and that is very amazing. I tried the first release in Alpha and I remember that next to NOTHING worked (which, the fact that ICS even booted on my Optimus was amazing to me. I was still super pleased with it, just unable to use it due to relying on my phone daily.)
The latest release, basically everything works! Only a few hiccups here and there, but the amount of stuff on it that works flawlessly boggles me. I'm very pleased.
I would love to keep up with your released via some sort of RSS feed enabled service. Is that a possibility?
Regardless, thanks again and keep up the amazing work! The Optimus V (and it's brothers and sisters) are great cheap phones, and having so many options for custom loaded ROMs extends the phones life that much more!
download goomanager from the play store, it SHOULD alert you if there is an update
Hey thanks, I'll check it out.
Oh and I think the only problem I'm really having that is kind of annoying is the system clock not updating. So I'll wake my phone and it shows me a time (usually like 10 minutes before the current time), put it to sleep, and wake it again and it will show me the actual current time.
