[ROM][BETA] Quattrimus ICS
skeetskat
4
3
I'm still having trouble with the I.valid package file on Google play some help would be great
As others have said, and what worked for me was to:
1) backup apps with titanium backup
2) backup the data from your sd card to your computer
4) repartition sd card in recovery (will erase all data on sd card, so make sure to back up)
5) move files back to sd card from computer
6) restore apps using titanium backup
It's a pain and a half, but this was the only method that was able to fix this issue reliably for me.
Reactions: chuckconnors
Badboytoast
820
122
Running for the past 4 hours at 480/748 interactivex, completely solid other than youtube still being a slideshow.
Thanks! My is also solid like a rock :D I am still on the official release! 07/03 480-825 scary , I'll keep an eye out till YouTube is fix! Overall excellent Rom! Its my daily:D
JadenBrown30
131
31
Installed beta a few hours ago and I love it :D thank you tdm your work is amazing.
There is one thing that I think would be a useful feature for this ROM, I noticed that the Galaxy SIII has a "kill all" feature when you bring up the running apps. Is there any way you can implement that feature into this ROM? Or would it be more trouble than its worth? Thanks in advance :)
Reactions: tdm
andrewnelson23
795
145
People keep complaining about Youtube. Yes, Youtube in the browser doesn't work.
But the Youtube APP does work!
Watching Olan Rogers' Ghost in the Stalls right now and it's PERFECT. So use that instead!
clodfelterac
Samurai Dev
Jan 3, 2012
729
206
@tdm--- aokp--0705- i partitioned sd to 512/64 for this one with cannibal... rom picked up and installed nicely... i stuck the default_oc script back in init.d... have only had three rr's total... two while adjusting settings, one while browsing with operamini... <-- last night*...
rom seems to have settled in nicely... : -)
Reactions: tdm
drizzzzzz
been using quattrimus for over a month as my daily. had to post about the battery life, it's unbelievable i can easily get three moderate usage days out of it on the new aokp with out any crashes..much better than the 10 hours on stock! thanks for the great work tdm i never expected this from my phone.
sammyz
825
190
I'm on quattrimus (not aokp) with my OV. I keep getting random freezes I haven't had before with the same OC settings I had.
Sent from my Optimus M
flapjack.fiasco
776
102
I concur, I haven't gotten a single reboot since it went beta (cm9 or AOKP).
Conrail16
118
22
Have you tried lowering your overclock a notch or two? I lowered my OC from 806 to 787 and got a large increase in stability. It seems like ICS puts a lot more strain on the processor than Gingerbread or Froyo did.
sammyz
825
190
Let me rephrase that, same OC settings I had on beta 1 pre 3.
19escape20
