@Tdm
Is there any progress about freezing/Force reboots when you turn Bluetooth on or off?
Not yet, but I'll get to it soon.
@Tdm
has any one tryed the AOKP nightly 7/05?
I'm still having trouble with the I.valid package file on Google play some help would be great
Running for the past 4 hours at 480/748 interactivex, completely solid other than youtube still being a slideshow.
cm9-nightly-20120706.changelog is 0 bytes. Checked the hash to be sure.
Saw that myself. Could mean no changes this build?
Build box was offline much of the evening. I'll need to investigate.
been using quattrimus for over a month as my daily. had to post about the battery life, it's unbelievable i can easily get three moderate usage days out of it on the new aokp with out any crashes..much better than the 10 hours on stock! thanks for the great work tdm i never expected this from my phone.
I'm on quattrimus (not aokp) with my OV. I keep getting random freezes I haven't had before with the same OC settings I had.
Sent from my Optimus M
Have you tried lowering your overclock a notch or two? I lowered my OC from 806 to 787 and got a large increase in stability. It seems like ICS puts a lot more strain on the processor than Gingerbread or Froyo did.
