inyourface09
So we got the hotspot fix?
Please Oh, Please Oh, Please im hating IHO
Thanks for anyone whos personally putting time into this I really apreciate it.
(although a useless post)
How the heck did you root the phone, put a custom recovery on it, properly wipe everything and install a custom rom on it and overclock it without knowing how to take a screenshot? haha it's easy as one-two. hold the power button. click take screenshot. haha
I knew HOW to take a screenshot, just not didn't know the benefit of it or what it did. Embarrassed to ask I like to figure things out on my own. I like to worry the big things first then sweat the small things
so im still experiencing issues when downloading anything from the Play store; after installing anything (even a keyboard skin) the system places a shortcut on the homescreen and tries to place a widget as well. ROM or ICS issue?
Sent from my Quattrimus ICS Optimus V
In Market settings is "Auto-add widget" enabled? If so, that places a shortcut each time a new app is installed to the home screen. Shouldn't be a ROM or ICS issue.
The benefit is if something is on the screen like what settings your running, keyboard too high, things out of the ordinary, you take a screenshot and upload it to let other bright ppl fix it. Lol
Leveled up twice and learned the skill dunceI get it now. Super Noob just gained +1000exp
So, by downloading the nightly, its actually just a updated build not an actual nightly patch that can be applied to the current build your running, correct? If not, then I'm confused, because they have the same bites
Yes, as of now nightly builds are full roms. Note that they are zip files.
