I have just gotten my first insufficient storage space message. It started after I cleared my market data from my apps menu. I think, looking at data, this might be coincidental. What I'm wondering, is why are all apks stored in data/app as well as on the ext. I've attached a df and, you can see I've got plenty of space on sd-ext, but not so much on data. Any solutions other than removing apps? Can i kill the automagic link and use a 2sd script? Can i move installer cache to sd-ext or eliminate the apks from/data? Tdm, any solutions?
Filesystem Size Used Free Blksize
/dev 209M 48K 209M 4096
/mnt/asec 209M 0K 209M 4096
/mnt/obb 209M 0K 209M 4096
/system 164M 146M 18M 4096
/data 178M 123M 55M 4096
/cache 110M 1M 108M 4096
/sd-ext 915M 546M 368M 1024
/data/dalvik-cache 915M 546M 368M 1024
/data/app 915M 546M 368M 1024
/mnt/sdcard 28G 22G 6G 16384
/mnt/asec/no.urtegata.go_theme_clean_white-1 3M 1M 1M 4096
/mnt/asec/com.fgol.grabatron1-1 35M 33M 1M 4096
/mnt/asec/com.foobnix.pdf.reader-1 5M 3M 1M 4096
/mnt/asec/es.paraisoft.android.aptoiderepos-1 2M 208K 1M 4096
