inceyet
@tdm--- well , i couldnt help myself so i overhauled the build.prop... added most of the s3 tweaks, adjusted some values, uncommented a few lines, removed a few lines, and cleaned it up a bit... ive been running it for a couple hours now and still no rr's, scrolling is smoother, data seems quicker, ui seems quicker, resolution seems much better (especially on keyboard, it used to look somewhat fuzzy)... i havent tested youtube yet to see if theres a difference, but after i post this i will... i didnt want the peeps getting confused with my posts... i attached the modified build.prop so you can have a look at it...
i love this rom!
to anyone running aokp, if you want to use this build.prop:
-download it to your sdcard
-use a root capable file manager (im using es because its color coordinated... lol) and go to /system and delete the build.prop, or make a folder on your sd called prop (or whatever) and move the original to the folder in case you want to move it back later (although i dont see why you would want to)
-now copy/move the modified build.prop to /system and paste
-save the changes
-reboot recovery
-wipe cache and dalvik
-reboot
id love any feedback... it works for me...
*do not flash the zip!
*unzip it, file is inside!
Which version did you use if it matters? And what are you oc at
GTR, AOKP, MiRaGe, CM9, BOBZ ICS, GODZILLA, Harmonia 2.08 killing the game!!!!!!!
