kjmott
I challenge that last statement, because we are now at least three persons with charging/power-related issues.
I've tried to troubleshoot this as best as I can; see Post #7384 in the archived thread (I'll migrate that to this thread when I have time). It would be useful if anyone with similar problems can confirm if they experience the exact same problems, or if they differ slightly.
A late update (not in that post): Twice (out of probably 30 flashes) I did indeed manage to get the charging going (always directly after a fresh ROM flash). However, after unplugging the power cable a few times, it would no longer charge whatever (rebooting, wiping cache, reflashing) I tried.. The 2nd time I got it to working, I didn't touch the phone and I confirmed that it did indeed charge (from 35-100%). To me it appears that there is some kernel(?) process that is in charge (pun not intended) of charging and that it is very unstable or not detecting the input current on our phones. Everything else works great with this ROM.
Please read Post #7384 before asking what I've tried; it contains lots of information.
Thanks,
Henrik
I did in fact read this post before I even asked for help. I did a search which brought me to that thread. I tried everything you did and I had no problems charging on the cm7 roms, but when I got to this rom again it still wouldn't charge. I have wiped everything. I was using an older recovery but updated to the cannibal 1.2 recovery. I still had 0 luck.
I have had zero problems ever going from rom to rom and then I hit this problem. I can't seem to figure out what the deal is with the charging.
when in cannibal open touch this is the process I used.
wipe data/factory reset
wipe cache partition
wipe system, data, cache
advanced ---> wipe dalvik cache
mounts and storage ---> format (boot, system, data, cache)
Then I flash the rom, then flash gapps
is there anything I am missing that I need to wipe.
should I format the sd-ext?
should I mount or unmount anything?
Thanks for any help. I really love this rom and I don't really want to go back to cm 7.2 with all the cool features on ICS.
Thanks for all you guys do.
Kyle
