henrikb
The battery level doesnt update on recoveries, so that makes no difference. Mine never charged from a touch recovery, only xionia. But I have no problems charging on an ics rom
When you say "battery level doesnt update", do you mean "it does not charge" or "the level reported does not update"? My question is whether I could let it sit on recovery (you suggest Xionia but not Touch) and actually charge, and then I can check the battery level by booting up into a ROM?
I'm trying to narrow where things go wrong and if I can also get it to charge in a recovery where you can charge it, I know at least something that works as expected on our phone (just as we know it charges on other ROMs).
