[ROM][BETA] Quattrimus ICS
sellersj27
94
11
I also had the same problem on zv4. But get this. Both aokp and cm9 only got unstable after I pushed my over clock past the limit. After that, anything I had it on was unstable..
I too have freezing occasionally that requires a battery pull on zv4... is zv5 any better?
cbucz24
195
38
Zv5 was pretty good. I made the mistake of upgrading to zv9. Call quality went up an seems no fc an less reboots. But data speeds dropped dramatic.
@tdm im downloading latest nightly to give a try. But sadly I won't be using as much soon. My evo 4g should be here Monday. Got it nearly nib for $70. Couldn't pass it up.
I'll still test your work on my v just to help but I won't have service much longer.
Too bad I couldn't talk you into building for my evo. Lol kidding I know your way to busy here. Thanks for all your hard work! You rock bro!
LeoLawliet
713
108
tdm, I just thought you should know that your ICS builds are more stable than ICS nightlies I've tried on officially supported devices, which are high end. Your work is amazing.
Sent from my LG-E739 using Tapatalk 2
Reactions: tdm
Badboytoast
820
122
Ian still on! Z4 and its solid like a Rock! I can OC at 864 with out a reboot! Yes on ICS too
I always use "pre for new rom" before flashing!
strabo231
497
96
Click to view quoted image
I have 32 apps installed and 1gb next partition but it still tells me that I am running out of space.
What's going on?Click to view quoted image
I'm confused... you have like 150 free out of 179. Why do you say you are running out of space? Clear your cache file and that will drop the number too. Also you have to remember that the app data stays on the phone and doesn't move to the ext unless you create another partition for data.
nitestalkr
889
261
Netflix ran on my gb too, but it was an ancient version of the app.
Netflix only works without sync issues on FROYO, on GB audio and video sync is off by a few seconds, theunknownartists made a GB rom themed to look like ICS, but wasn't actually android 4.0.
A few months ago, Netflix changed the way the app connects to The server and check for updates, forcing all older apps to update, so there is no work around. Netflix will ONLY work without any issues on Froyo based ROMs.
sent from my un-dead sammich in my hospital bed.
inceyet
393
121
kirk781
