drezliok
I'm confused... you have like 150 free out of 179. Why do you say you are running out of space? Clear your cache file and that will drop the number too. Also you have to remember that the app data stays on the phone and doesn't move to the ext unless you create another partition for data.
So I need two 1GB Ext3 partitions? I mean I had a full wipe including SD-EXT before flashing. I'm just wondering how I can run out when I am no where near the end of a GB worth of storage.
