K
kobequintana
That is truly remarkable.
sent from my un-dead sammich.
How
This Song Rocks:
Forever Given Forever You
By: Evanescence
https://www.youtube.com/watch?v=naI5swhuoeI&feature=youtube_gdata_player
AOKP doesn't have any options to disable specific rotations, 0, 90, and 270 are enabled by default in AOKP, but in CM9 you can disable them individually, and that setting stuck when I dirty flashed aokp.
Its because it doesn't exist in AOKP, so the script doesn't wipe it (if the script wipes anything), and then, only 0, and 90 are rotatable, 270 doesn't rotate.
So no, its not a placebo. Its the setting persisting from CM9 into AOKP.
Could it be the version of gapps he's using?
How
This Song Rocks:
By: Evanescence
Because you're the only one that doesn't need to reflash gapps.
I'm using thekravens small gapps.. are you?
Is that good or bad lol XD
This Song Rocks:
By: Evanescence
1am, huh? Ugh, fun times indeed! Glad you got them though!
Your G-1 first look video today was great! I love that you can add Folders to the Home screen and put stuff in it like your games. Sweet!
Yes. Kobe where did you get your gapps?
Well that's one less thing you need to flash, so its good I guess. xD
Do you know what version of gapps you are using??
small gapps has always given me problems I'm using the full 20120429 version
Edit: obviously quoted wrong post. I apparently have developed fat finger syndrome with swype
Well, I looked in the updater-script, and there isnt anything set to wipe system. I though there was. Sorry for the confusion
Sent from my VM670 using Tapatalk
Do you need to flash gapps each and every time to get Google stuff working??
Can somebody suggest a good overclock for AOKP?
With small gapps I had to do it everytime. After I switched to the full version I never did.
