Any idea on when AOSP will be out? Ever since I saw a post that said google now might be ported into it I've been checking everyday. I have gotten google now installed but because of the voice issue it only works if I type.
While updating it says to click on the android to start setup wizard. Well I press it and it says "unfortunately, Setup Wizard has stopped"
Some one help pls. I downloaded the CM9 well installed that one but I have both. Optimus V
Can someone paaallleeeeaaaasseee pm me the link to the aokp YouTube fix? I'm not gonna be near a computer for a few days so I can't search for it. I'm on tapatalk.
Sent from my A.C.R. Zombified Quattrimized AOKP OV.
The current fix requires a computer to work. It's basically streaming YouTube through a PC to your phone. It works decently if your computer is fairly fast, and you have a decent upload speed on your home connection.
But honestly, if YouTube is important to you, you should run something like MiRaGe or Harmonia. You won't need to use any fixes.
Or just use CM9.
sent from my un-dead sammich.
I haven't used CM9 in a while. Is it pretty clean on there now?
Just follow the guide
Which guide
Sent from my VM670 using Android Central Forums
I'm currently on the beta1 aokp. I remember using a screen filter on an alpha build. It allowed you to edit screen colors to save battery file.
Settings > Display > Custom Backlight Settings > Edit Other Levels...
When I try to go to this it says "Unfortunately, Settings has stopped."
Is there a way to fix it or an alternative?
