jensonco
Not sure why you saw what you saw, but no, it's not possible, with this or any other ROM.
I'll take a screenshot next time. It was odd, lol.
Yea, Virgin Mobile doesn't allow Roaming at all, yet you're not the first to report momentarily roaming.
I've read here, and in other Android forums of Virgin Mobile users, typically with the Optimus V, have experienced several cases of Roaming, with a wide variety of several Roms.
sent from my un-dead sammich.
Correct, no need to wipe data.
Try 729max 600min on savagedzen.
You just gotta spend a lil trial and error messing with several combinations to find what works best for your phone.
So is the AOKP 31st version the only one going beta 2, or is cm9 31st going as well? Also, when is it and can I just download the 31st file now or will the beta 2 release differ from it in any way?
Hey tdm, I think the system is reading sdcard free memory wrong, because I should still have around 5gb left. Not 1.5....
Click to view quoted image
Sent from my Quattrimized AOKP OV.
So still no youtube fix for aokp?I just find it hard to beleave that after all this time noone has figured this out.....
You guys ever see that post leslieanne put up about them supposedly implementing roaming? Think it said it was supposed to have been July 1
what now i keep getting no space left for anything i did 512MB and in setting it says i have used 212MB from the 179 MB so i know it is somewhat working but no space for a 2.12 MB file...?
Yeah but that was only a rumor spread by an uninformed public relations individual.
I was thinking this myself. But apparently it doesn't work after flashing gapps. Maybe it would work if tdm himself took the lib files and whatever else is responsible from cm9 and put them in aokp, then we could just flash itCan't we just get the thing that messed up out of aokp and import the one from CM9
Song of the week:
Song: End Of The Dream
Band: Evanescence
Album: Evanescence
https://www.youtube.com/watch?v=GdSIaDv7K74&feature=youtube_gdata_player
