Got beta2 promoted, it's the 7/31 nightly. Please let me know if there are any issues with the web pages or links. Like I need to ask...
Ok im commin from bobz cm9 with a partition. Do i wipe everything and the ext partition?
Does any one elses phone reboot when you try to start the camera? My screen will go black then reboot.
Try setting your overclock settings down. That a telltale sign that your juuuust a little overclocked. Least that's what I've been told..
Sent from my twice fried OV using Quattrimus for life support!
Links down??
Which links? Try getquattrimus.com
I see a beta 2 does that mean we have to do a full wipe or just do a dirty flash?
im only at 748MHz any more power and the phone will power off the sec i click it.
Tdm,
Do you need volunteers to test your 3.0 kernel?
