nitestalkr
Does anyone with the battery charging problem know if this is fixed in beta 2?
Wasn't sure what all was changed in beta2 but before I flash I thought I would check.
For now I'm stuck with 7.2
It wouldn't hurt to check it out yourself, I'm sure others that have that issue are staying away from Quattrimus till it is mentioned that its fixed. And the only people that can test this, would be the ones with that issue. So give it a shot, and report your findings.
sent from my Zom-"Bean"(AOSP JellyBean).
