kcls
Did everything on goo.im just disappear? Like, everything?
Ya, that's my guess. We'll have to find a way to mount that to sd-ext also.....
My battery drains like crazy on cm9 as well. Mostly when i'm surfing over 3g or have bluetooth on and connected
I don't have 3G here (and it would have been far more than a 2 hour drive, each direction, to get into one), so I just bought one on eBay for about $400 (including overnight shipping). T-Mobile told me I could stop by and "look" at their display models and ask as many questions as I wanted. No thanks.
Has anyone else picked up a G1? If so, where and how much? Are you using it yet? I can't wait for mine to arrive
I rooted my phone, if i install cm9 will it delete my data that i have on the games that i play ?
Sent from my SPH-D700 using Android Central Forums
removed by moderator
Server maintenance this weekend.
Nope, actually, apparently their whole filesystem got nuked. Everyone's files are gone.
I'm back to using CM7 also because of the bad battery drain using CM9. My battery would last only around 5 hours, even using the aggressive setting with Juice Defender. I had to bring my charger with me everywhere I went. The battery stats in CM9 would show my phone being awake almost the entire time even though the screen would be off, wifi disabled, any only periodic 3G usage with good reception. During normal usage, typically just browsing the internet and checking messages/email, my battery would drop %3-5 in 10 minutes of usage.
Thanks so just back up all user apps ?
My battery lasts about 16 hours on CM9.
sent from the hip.
Okay now I got a question for you guys. I've been having a problem with reboots when i'm using 3G. I know a few of you mentioned different gov's and oc's that seemed to slow it or stop it, and i've tried a few market apps for signal tweaks and such, but I'm just not having any luck with it. That is really the only major problem i've had since I got the phone replaced last month though...even managed to get it to let me oc it without it rebooting constantly!
