@tdm. Is there any chance you could make a button combo for screenshots?
Probably something for a modder to do.
But you can add screenshot to the power menu, check through the settings it's in there somewhere.
I'm pretty sure there already is a button combo... I use it on bobz ICS anyway... power and volume down
you could change your prl. i got WAY better data speeds after doing that.
Maybe a dumb question, but did you select the split setting for messages over 160 characters in the messaging settings?
So i may have screwed myself over here.
I followed this:
To wipe clean 100% and install a new rom
Select ?wipe data/factory reset
Select ?yes?
Go to ?mounts and storage?
Select ?format /boot?
Select ?yes?
Select ?format /system?
Select ?yes?
Back out of that menu to the main one again and select ?advanced?
Select ?Wipe Dalvik Cache?
Select ?yes?
and flashed the ROM.
Now my data won't work. I flashed my recovery and it's still down.
Any idea what I can do?
Thanks for the solution. Can't believe I totally missed a settings menu for Messaging. The red exclamation sign with no explanation kept throwing me off. Google should make it pop up a message like:
"This message is too long to be sent as a single message. Would you like to split the message into multiple texts? (standard text rates apply)." With a check box "Automatically do this for all messages from now on." Or at least make it automatic.
Your data won't work? You have a V?
Toggle airplane mode and data. That should bring it back.
It is a V. :/
