cole2kb
Retired Moderator
And what is with the app in the app menu in the settings call Unicorn Porn??
Wallpapers.
Does it make a difference that i partitioned it before flasking AOKP? And will it tell me if they're forced over to the sd card? or will it keep telling me that they're phone only
And what is with the app in the app menu in the settings call Unicorn Porn?? and why is it that every time i reboot my phone a window pops up that says "Android is Upgrading" "Optimizing application x of x"
Goto the very first post, and click either link labled primary, or alternative.
Download links are there.
sent from my Zom-"Bean'(CM10 JellyBean).
How do I flash my phone and fill the gapps and stuff like that.
http://forums.androidcentral.com/showthread.php?t=108282
[HOW-TO] Simplified Root + Recovery + Custom ROM
That should explain things
Do I need to root my phone
Yes.
Can someone give me the download links to ics root and ics recovery image.
Read the link I posted it has root recovery image and a custom ROM
I want ics not gingerbread
Are you on stock rom
OK than that thread will work that's how I rooted and got my recover etc
