brotherswing
I found the culprit for the phantom lock screen issue I reported a while back. Handcent is the issue, not the rom.
sent from here to there...
I have 258MB of app storage on internal memory. Thing is, that the apps are all actually on sd-ext (I've checked multiple times, and this is correct) and mounted to /data/app. Is it possible that the system is reporting /data/app usage as internal usage, even though it's on an external sd-ext? How would this be fixed? I've "hit" the memory cap, even though I'm using sd-ext.
That's old code and it's already in there.
Does a SD partition make the system any faster?
Hmm. I guess I can understand that. But the reason I don't get it is because I have at least 500-600MB free on my sd-ext partition (just checked), but internal storage lists 40MB free left.
We should move /data/data to sd-ext in the ROM then... I think that might solve our problems then. Because internal space still dwindles down quickly, though not quite as quickly as with apk's on internal, but still.../data/app and /data/dalvik-cache is moved to the sd-ext but /data/data isn't and that still fills up with a bunch of libraries and app storage. I have about 90 apps installed and have 32mb free even though I have 923mb left on my sd-ext.
So there is still a limit.
Yeah I can do that .. Might make it an optional thing.
Ya, of course. I would expect it to be optional. Thanks.Yeah I can do that .. Might make it an optional thing.
Afterburner could be modified to display the circle style battery indicator, I'll talk to Anthony about it. I'm working on two roms right now plus I got married today, otherwise I'd offer to do it myself.
