BlairFam07
Active member
I would also give https://forums.androidcentral.com/e...S5rb3VzaGlrZHV0dGEudGV0aGVyIl0&token=D4C_mSh_. A shot it's free!
Use adb. Look it up on the forums, there is tons of info. Google too.
The file is /proc/last_kmsg
Uh adb I've tried to set it up but it never works, I found the file on es file manager. How do I get you a copy?
After that, what do I do?If the only way you can get to it is es file explorer, just long press the file and it'll bring up a copy option, select that. Then go back to the main to the main root directory, select sd card, and then
long press a blank spot on the screen to paste the file. Now it's on your sd card.
how stable is this against bobz cm 9
Posted it on paste bin, what's next?
It looks like aokp has abandoned ics, I'm thinking the next builds might be jb.... Also thinking about giving gummy a spin.
Lol don't get all teary eyed, quattrimus is about Android 4, and jb is still 4. It is certainly going to take some work to get back to what we have with beta2, but we went through this before... Remember the 4.0.4 upgrade for alpha8? That sucked but it all worked out.
