sellers86
I haven't looked at the official requirements for ram but I have no reason to believe that 512mb is going to be a problem. It's the flash size that's our biggest issue.
I will be starting to work on jb shortly, and when I release, I expect it will require sdext. I plan to put system apps on it this time, which means you won't be able to remove or change your sdcard without either a backup and restore or a reinstall.
I would be sure to state in big bold red highlighted letters that the rom won't boot if you take out the sdcard. Even though half of the people won't see it.
Sent from my One V using Android Central Forums
