brotherswing
I dunno, my OV runs like hot garbage on all the JB builds I've tested. I can't imagine that 4.2 would run any better....
Thus he spake
Thus he spake
Thus he spake
i found it and a few other decent games here (armv6)... thanks to AndroPalace and Manoj The Gamer...
http://www.andropalace.net/
THE GAMING PLACE [GALAXY Y/DUOS Only] [UPDATE] - xda-developers
Anybody looking for a v6 compatible templerun i have aan apk
Sent from my Kindle Fire using Android Central Forums
Is there a way I could get the fast charging mod onto Quattrimus like Cold as Ice?
Cold as Ice was really buggy for me and now I want Quattrimus.
But I also want fast charging.....
Can you find the commit in kravens github?
Audio Routing Fix: https://github.com/thekraven/androi...mmit/aa64ba88a9b34ac264c9f66486e9f36cad3b6fea
Camera Fix added late last month: https://github.com/thekraven/androi...mmit/0eafd36896af4ed2e0b68925bcf52cf774a6429d
Unfortunately, I can't find the USB Fast Charge commit. I also couldn't find the Home Button to answer call commit. I will continue searching, though. The later is important to me, the former seems to be popular right now (I never use it, anyway).
Flash TheKravens latest kernel. Then flash his patch.
What file system is it formatted to?
Thus he spake
FAT32...? I think
You need to have your SD card formatted in two partitions, one (the first) should be in fat32, the other should be in EXT format, either EXT2, 3, or 4. Myself, I would mount my phone by USB, then copy all the info off, then boot into recovery and use the recovery tools (in CWM or COT) to format your card correctly.
I'm not 100%, but I think that patch is just to add the toggle to the interface. The fastcharge option is in the kernel, but you need a method to enable it in some interface. The Quatt AOKP builds already have the toggle present, so it's just a matter of including the code in the kernel to disable the ADB and enable fastcharge. I'm still trying to find that code.
Could I run Link2SD in Quattrimus with a FAT32 partition?
There shouldn't be any lost apps because there'd only be 1 a2sd service running.
Right?
No. No. No.
That will break things. Honestly, your best bet is to copy any data you want to save to a pc, then use your recovery to redo your partitions. There may be other ways to force it to work, but this way will give you the best possible performance.
Thus he spake
