DarthBill13
How do I turn off automatic brightness off? I looked in display in setting I didn't see an option so I put the power widget and that didn't help. After that I dis the status bar widget and that too did not work.
Sent from my LG-VM670 using Xparent Red Tapatalk 2
Go to Menu->System Settings->System->Notification Drawer->Widget Buttons then scroll down to Brightness modes. There you should be able to customize it how you want.
