[ROM][BETA] Quattrimus ICS
kenharkey7
222
18
Hey haven't used this rom on a min due to the video lag like on YouTube ...was there a new release that fixed it or is there a work around it
Me thinks not, for lagless YouTube on ics, cold as ice is still the only way to go
JimReid
6
I downloaded the quattrimus-VM670-cm9-beta.zip and it hosed my phone. Took over an hour to factory reset and get back to the last backup that I had. After installing the release all I got was a picture of a robot with an evil smile. I think maybe this zip file is compromised.
AndyOpie150
1,254
32
Did you check the md5 sum of the download to make sure it didn't become corrupted in the download process.
If you have an sd card partition: You need a 1.5 GB ext.3 partition on the SD card. An 8GB card or bigger is needed.
Finsrepair
