I got a boot loop (or frozen at boot logo) after install of simple2ext. I hate the small space for apps. Can you help me get sd-ext support working?
I install by
1. Flashed ICS_simple2ext.zip using clockworkmod recovery 3.2.0.1
2. reboot system
3. Did not find s2e in apps so extract s2e.apk to /system/app
4. extracted "20userinit" to /system/etc/init.d
5. found "90userinit" in /system/etc/init.d and renamed to "90userinit.old"(Did not want do delete. You know be safe, always backup.)
[ROM][ICS][UNOFFICIAL] CM9 BETA3 based port for Legend [JUN17] - Page 94 - xda-developers
7. Run the s2e app from App Drawer.
8. Press Menu button within s2e app and go to Settings.
9. Check Mount as Ext4 option. The sd-ext must be formatted to ext4!
10. Check Advance Mode option.
11. Now, reboot your device.
Now over 10min on boot screen as of writing this post. Good thing I have a pre simple2ext backup!!!
How to Move Apps and Data To SD-Ext Partition on CyanogenMod 9 Android Rom?
xda-developers - View Single Post - [BETA 0.15.0.1][04.07] ICS for Desire[ALL HBOOTS][4.0.4]
Now, after the reboot (CAN'T BOOT LOOP), run the application again and then select (check) Applications, Private Apps and Application Data and then reboot your device from s2e menu.
Thank you!
I install by
2. reboot system
Thank you!
