aimlessanomaly
So any idea what I should do if I forget to set the permissions and end up with a black screen and unable to boot?
I think that the flashable zip posted by mrg right about your post will prevent that from happening by setting the permissions for you. However, make a backup before hand.
What I'm trying to say is I forgot to set the permissions and cannot boot :/
I have attached here a flashable zip file that will do the trick for you. Like bigsupersquid, I am not sure if there is any difference and Antutu is giving exactly the same 2D/3D GPU scores. Anyway, it is good to have one less library in the ROM as long as we can do without it.
mrg, it will be a sad day indeed when you finally get the banned today/not banned tomorrow Galaxy Nexus (damn that rotten fruit). I know that you'll still have OVs around, but that new toy will take most of your dev time.
Thank you mrg666, I'll try it out and if it works I'll mention it on the first post.
As they say, don't mention it
Soft brick meaning bootloop? I get confused with meanings.
instead of removing the original .cfg and .so, i renamed em with an added .old extension in case i had to put em back
i haven't noticed any differences yet myself, but it's only been a half hour or so of testing.
So can you just flash and not do the root explorer thing??
Ok so here it went, flashed the zip
Before:
Click to view quoted image
After:
My cpu settings:
It was pretty laggy when I first booted up but it does feel a bit...smoother now
