b34tls4ever
Confirmed working noticeably on ics too
Sent from my LG-E739 using Tapatalk 2
i tried this on Quatrimus and it got stuck at the boot sceen
Is there a flash zip for the new build prop tweaks I suck at doing stuff manually
I have attached here a flashable zip file that will do the trick for you. Like bigsupersquid, I am not sure if there is any difference and Antutu is giving exactly the same 2D/3D GPU scores. Anyway, it is good to have one less library in the ROM as long as we can do without it.
Okay, just installed via the flash method (I'm on Gingersnap 1.4). So far, it does seem to have a bit more pep, and less lag. Keyboard is much zippier. The oft-sluggish Google Play loads faster. Facebook is still a pig.
Here's what I did:
1. Used File Manager (my fave!) in root mode to check the permissions on egl.cfg. Since I reflashed this past weekend and fixed permissions as part of my usual process, the values were already correct (rw-r-r). Double check anyways.
2. Nandroid backup, natch.
3. Flashed mrg666's zip
4. Reboot normally
5. For the build.prop tweaks, there's an app for that!
App Build.prop Editor v1.0 ? xda-developers
https://forums.androidcentral.com/e...han.jf.build.prop.editor&hl=en&token=J9O1fXN3
The build.prop editor can also make a backup, just in case.
Entered all the values, but for dalvik.vm.heapgrowthlimit, I couldn't find that entry. Nor did you mention the correct value to enter. I did nothing with it.
I just added these tweaks and will play around with it, so the final verdict is still out. But so far, my phone is using far less memory and CPU power. Hopefully it stays this way. I love these little tweaks!
I don't remember the dev who posted the build.prop tweaks mentioning anything about adding a value onto vm.heapgrowthlimit, he just left it blank. To be honest I think it's already in the build.prop anyway, it would be kinda pointless to add that one line.
Edit: try out this build.prop tweak, it speeds things up a bit more.
Open build.prop and add the following
change dalvik.vm.dexopt-flags=m=y TO
dalvik.vm.dexopt-flags=m=y,v=n,o=v,u=n
right below add
dalvik.vm.execution-mode=int:jit
then change windowsmgr.max_events_per_sec = 300
comment out with #
then save
It was mentioned in your first post:
Didn't know myself, so I just skipped it. Works fine.
soo should the build prop look like this
dalvik.vm.heapsize=48
debug.sf.hw=1
#dalvik.vm.heapgrowthlimit#
Should I make a thread for this on XDA?
Does the -
debug.sf.hw=1
Come right below this line-
dalvik.vm.execution-mode=int:jit?
Or does it go somewhere else- also do I need to change the timing thing to make the whole build prop edit work?
Thanks
