1. Zakman's Avatar
    Hey guys im making a port, And I've made the port and the initial setup when it first starts does not pop up, which makes the home button not work, is there anyway to fix this?
    07-16-2012 11:49 PM
  2. sellers86's Avatar
    flash gapps?
    07-16-2012 11:52 PM
  3. ThatGuyLurkin's Avatar
    And home button should work. Look at Harmonia.
    07-16-2012 11:54 PM
  4. sellers86's Avatar
    i believe hes using ICS as a base. which means if you dont flash gapps, no home button or setup.
    07-16-2012 11:55 PM
  5. Zakman's Avatar
    I flashed Gapps, But niether of them work.
    07-16-2012 11:58 PM
  6. Zakman's Avatar
    The base im porting from is BobzHome's ICS.
    07-17-2012 12:18 AM
  7. sellers86's Avatar
    how big is the rom?
    07-17-2012 12:56 AM
  8. ThatGuyLurkin's Avatar
    What are you porting?
    Sent from my Motorola Triumph using Tapatalk 2
    07-17-2012 12:56 AM
  9. Zakman's Avatar
    how big is the rom?
    102mb
    07-17-2012 02:04 AM
  10. sellers86's Avatar
    102mb
    Gapps won't take then. You need to put the rom on a diet. Its to big.
    topdawg661 likes this.
    07-17-2012 02:10 AM
  11. topdawg661's Avatar
    Bowflex ^_^ sorry had too lol
    sellers86 likes this.
    07-17-2012 02:18 AM
  12. TauSigmaNova's Avatar
    Not at all- VanillaBean_0.05.zip, the one I released as the first build was 103 mb and GApps flashed, and the earlier indev builds were even larger upto 111mb...
    07-17-2012 02:28 AM
  13. Nate456's Avatar
    It also depends on the size of the Gapps packaged.
    07-17-2012 02:34 AM
  14. cole2kb's Avatar
    Just a quick note -- any developers that are working on a Jellybean port for our phones that I haven't contacted already, please contact me before you post a release.
    Thanks!
    topdawg661 and sellers86 like this.
    07-17-2012 02:35 AM
  15. sellers86's Avatar
    Thanks!
    And by this he means jellybean, not ics with jellybean apps.
    07-17-2012 02:42 AM
  16. TauSigmaNova's Avatar
    Which can be found in my signature!
    07-17-2012 04:08 AM
  17. flapjack.fiasco's Avatar
    Thanks!
    Just curious, why?
    07-17-2012 09:10 AM
  18. sammyz's Avatar
    Just curious, why?
    Bump, I'm also wondering.
    Sent from my Optimus M
    07-17-2012 10:59 AM
  19. cole2kb's Avatar
    So I can get it FIRST. J/k, j/k. Just coordinating on the release to avoid another thread that ends up being a mess.
    07-17-2012 11:15 AM
  20. Zakman's Avatar
    So should I slim down the rom?
    07-17-2012 03:04 PM
  21. sellers86's Avatar
    Try that. And use a smaller gapps package.
    07-17-2012 03:30 PM
  22. ThatGuyLurkin's Avatar
    You just helped me out Sellers. Maybe now I can fix a boot problem I'm having.
    07-17-2012 03:53 PM
  23. sellers86's Avatar
    Good!
    07-17-2012 05:07 PM
  24. jonny5449's Avatar
    yes that would help
    Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
    Zakman likes this.
    07-17-2012 05:07 PM
