04-19-2013 12:12 AM
487 ... 1112131415 ...
tools
  1. clodfelterac's Avatar
    new problem, everytime I try to do usb storage for my phone to my computer, I get a notification that says you can safely remove sdcard...?
    Waiting for others to report back on these issues, also, check the S thread and see if these are bugs they are reporting as well, or if they are specific to us, and I'll update the OP accordingly.
    i can confirm usb mass storage isnt properly mounting sdcard... i checked the s thread and didnt see any mention of the problem there...
    07-25-2012 03:04 PM
  2. nitestalkr's Avatar
    Any further discussion about using my patch with any other ROMs other than Jelly Bean, will be held here:
    [Guide][Port][WIP]Porting ANY OptiS rom to the OptiV in 1 Flash!!
    Other than that, feel free to discuss how it works with Jelly Bean, or any contributions to the zip for jelly bean.
    diecastdonkey likes this.
    07-25-2012 03:15 PM
  3. StumDroid's Avatar
    Which method are you using?
    And which ROM(assuming JellyBean)?
    I'm trying to get headphones fixed, I got all the files and such but it refused to boot in, so I'm going to try another method and if it does in fact work I will post the files needed. I'm getting close I can feel it
    07-25-2012 03:38 PM
  4. Super R's Avatar
    Anyone tried bluetooth calling/music on cm10?
    07-25-2012 03:50 PM
  5. nitestalkr's Avatar
    Yea, I found out that the auido lib files were breaking boot when I made the flashable zip...
    I'm still looking into it..
    07-25-2012 04:05 PM
  6. clodfelterac's Avatar
    easytether works for wired tether... :-)
    nitestalkr likes this.
    07-25-2012 06:51 PM
  7. andrewnelson23's Avatar
    WE HAVE TETHER ON CM10 ALREADY?!? :what:
    07-25-2012 07:23 PM
  8. dja041687's Avatar
    Been running this all day and I have to say yall have done a wonderful job. Everything is smooth and pretty snappy on stock cpu sets, love the stock launcher but I'm probably going to switch to nova because I just like the extra features. I dont have too much to complain about. Common apps are force closing on me such as google voice, and facebook and I couldn't figure out why. This makes the rom unusable to me as I use google voice more than I use anything else. No google now which is weird. I don't have service on the phone right now so I can't report on DATA or messaging, Maybe soon. I hope yall keep up the hard work because to JellyBean is to Ice Cream Sandwich as Windows 7 is to Windows Vista. Lol It just has those simple features that make you wonder why didn't google do this in the first place. Like the auto resizing widgets, and the new notifications bar. Love it
    07-25-2012 07:28 PM
  9. andrewnelson23's Avatar
    thanks for the confirmation man. Can you confirm about the play store??
    07-25-2012 07:34 PM
  10. clodfelterac's Avatar
    play store works for me... :-)
    07-25-2012 07:37 PM
  11. cole2kb's Avatar
    Working through apps isn't major. Built-in is always what is hard to get working.
    07-25-2012 07:43 PM
  12. andrewnelson23's Avatar
    No, it works for me as well, but it recognized my device as an LS670, so I couldn't install certain apps. (like youtube or netflix). I tried it on the play store on the computer as well, but that's what told me it recognized my device as ls670. it's annoying. anyway, I went back to quattrimus and it lets me download those apps on my device, but tried going to the play store on the computer and it still says I'm a ls670... -_-
    07-25-2012 07:46 PM
  13. clodfelterac's Avatar
    i adjusted a few lines in the build.prop before flashing so it would be recognized as a v... ive had no problems... youtube works, pandora says not compatible in the store... but i havent tried loading it from sd yet... im still in awe that its running so smooth with minimal modifications, minimal bugs...
    Code:
    ro.product.model=LG-VM670
    ro.cm.version=10-20120715-UNOFFICIAL-vm670
    ro.modversion=10-20120715-UNOFFICIAL-vm670
    andrewnelson23 likes this.
    07-25-2012 08:21 PM
  14. andrewnelson23's Avatar
    Code:
    Cole, can you post this fix in the OP? Otherwise, people can't download certain apps from the play store.
    inceyet likes this.
    07-25-2012 09:00 PM
  15. nitestalkr's Avatar
    I'll incorporate it into my jellybean fix later today
    sent from my un-dead sammich.
    inceyet likes this.
    07-25-2012 09:07 PM
  16. andrewnelson23's Avatar
    Oh I didn't know you had a specific jellybean fix.
    07-25-2012 09:10 PM
  17. nitestalkr's Avatar
    It's basically the same as my other patch, but I will include specific Jelly Bean fixes(build.prop edits etc), only in this one(second post here).
    And the one I made a thread for, is going to be universal. They currently contain the same files, but that's changing sometime tonight when I get around to it.
    07-25-2012 09:26 PM
  18. clodfelterac's Avatar
    fixed headphones!...
    -replace audio_policy.config in system/etc with the one ive attached... :-)
    *no it is not flashable... the file is inside...
    * place the file pre flash...
    07-26-2012 01:52 PM
  19. Super R's Avatar
    Excellent work Is the mic on the headphones working for calls?
    07-26-2012 02:48 PM
  20. clodfelterac's Avatar
    i dont know... i only use the headphones for music... please test it and see... report back and let us know... :-)
    07-26-2012 02:58 PM
  21. andrewnelson23's Avatar
    Hey I still get errors when using the play store. It works and stuff, but it thinks my phone is an ls670 optimus s. I changed a bunch of things in the build prop, but it's still not working.
    07-26-2012 03:02 PM
  22. clodfelterac's Avatar
    you could try these...
    Code:
    ro.product.brand=Virgin_Mobile
    ro.product.name=lge_vm670
    ro.product.device=VM670
    07-26-2012 03:16 PM
  23. andrewnelson23's Avatar
    I changed everything that said ls670 to vm670
    I was just comparing the build.prop to quattrimus's. In the ro.cm.version, at the end, I put vm670. Does it need to be VM670?(just a capitalization thing?) I did the same thing for the ro.modversion at the end.
    07-26-2012 03:19 PM
  24. clodfelterac's Avatar
    not necessarily... test and see...
    07-26-2012 03:33 PM
  25. JussCallMeUno's Avatar
    So everything works? Even audio?
    07-26-2012 04:28 PM
