04-18-2013 11:12 PM
487 ... 1617181920
tools
  1. jonny5449's Avatar
    @zakman
    You ported jellybean huh
    What works and what doesn't
    Sent from my LG-LS670 using Android Central Forums
    08-02-2012 09:33 PM
  2. anthonycr's Avatar
    Actually I ported a different one but that will work too.
    08-02-2012 10:11 PM
  3. Zakman's Avatar
    Ported it, didn't boot :/
    08-03-2012 11:15 AM
  4. anthonycr's Avatar
    I failed to mention you have to use a boot.img from an OS or OV ICS rom.
    08-03-2012 12:23 PM
  5. jonny5449's Avatar
    Boot img
    Never knew what that was I just steer clear
    08-03-2012 01:20 PM
  6. Zakman's Avatar
    I did change out the boot.img
    08-03-2012 01:46 PM
  7. clodfelterac's Avatar
    Boot img
    HOWTO: Unpack, Edit, and Re-Pack Boot Images - Android Wiki
    08-03-2012 02:51 PM
  8. anthonycr's Avatar
    Boot img
    Lol... how do you port without knowing what the boot.img is... it's the engine of the operating system.
    sellers86 likes this.
    08-03-2012 03:25 PM
  9. anthonycr's Avatar
    Did it just show a black screen?
    08-03-2012 03:26 PM
  10. sellers86's Avatar
    that's a good guide for linux users (not sure if it works on windows) but use dsixda kitchen. It 15000000000000000000000x easier to use.
    08-03-2012 04:41 PM
  11. sellers86's Avatar
    Boot img
    It contains the kernel and the ramdisk files.
    08-03-2012 04:42 PM
  12. anthonycr's Avatar
    Ditto
    08-03-2012 05:50 PM
  13. jonny5449's Avatar
    I never knew how to include kernel that's cool
    Also I can use guide I'm Linux/windows/Mac user so I can also do dsixda
    08-03-2012 05:51 PM
  14. ThatGuyLurkin's Avatar
    Since this is a support thread, can someone teach me how to unpack a boot.img via TeamViewer or something?
    Those guides NEVER made sense to me.
    08-03-2012 06:40 PM
  15. sellers86's Avatar
    Yes, when I get home I can. Send me a pm with some easy way ti get ahold of you
    08-03-2012 07:08 PM
  16. Zakman's Avatar
    No, it dimmed the boot animation but never booted in.
    08-03-2012 07:54 PM
  17. anthonycr's Avatar
    Well that means its not a kernel issue. Probably framework-res is refusing to work... I have no idea why it would do that. Try copying all the extra lib files and bin files from drews port into your port, and see if it boots.
    08-03-2012 08:33 PM
  18. Zakman's Avatar
    Ok I ported lugohirps p500 rom but radio still isnt working for some odd reason.
    08-03-2012 10:16 PM
  19. anthonycr's Avatar
    Flash nightsalkrs patch for zvd
    08-03-2012 10:20 PM
  20. Zakman's Avatar
    UPDATE: Got Data and radio working without color banding now im working on sound issues... but should be an easy fix and GAPPS Sticks
    nitestalkr likes this.
    08-03-2012 10:52 PM
  21. nitestalkr's Avatar
    btw, here is the list of files that arnt in the p500 rom(besides browser, it was actining up for me on the p500 rom so i replaced it):
    Code:
    app-----
    browser.apk
    bin-----
    cnd
    netmgrd
    port-bridge
    rmt_storage
    su
    tsdown
    wl
    qmuxd
    etc-----
    init.qcom.bt.sh
    init.thunderc.usb.rc
    MELFAS_FIRM
    profile
    setwifi.sh
    apns-conf
    FIRMWARE--
    wlan
    PERMISSIONS--
    android.hardware.telephony.cdma
    android.hardware.touchscreen.multitouch
    lib-----
    libjackpal-androidterm4
    libloc_api-rpc-qc
    libreference-cdma-sms
    libstagefrighthw
    MODULES--ALL
    Also, does anyone know the correct RIL files to replace?? I have this list from a different phone port but im not sure if its correct:
    I believe those are all RIL files.. I know there's 1 or 2 in the /bin folder that control RIL stuff.
    sent from my un-dead sammich.
    08-03-2012 11:54 PM
  22. Zakman's Avatar
    I got it working, now working on audio.
    08-04-2012 12:13 AM
  23. Zakman's Avatar
    @nitestalkr these are the files I used for the issues with the color banding:
    Color Banding.zip
    Place them in system/lib and it should fix it. I havent tested them but they should work.
    clodfelterac and jonny5449 like this.
    08-04-2012 12:24 AM
  24. nitestalkr's Avatar
    Color Banding.zip
    Thanks, I'll test it soon, and if it fixes it, I'll incorporate it in both JB patches, and add even more thanks to you in the op.
    08-04-2012 01:14 AM
  25. Zakman's Avatar
    Just tested. They work!!
    08-04-2012 02:08 AM
487 ... 1617181920
