04-19-2013 12:12 AM
487 ... 56789 ...
tools
  1. andrewnelson23's Avatar
    I wouldn't try it like that, just place the files in the zip itself, but do not unzip the ROM file, if you do, and try to zip it back up, it won't become flash able due to the default compression method used.
    sent from my un-dead sammich.
    It wouldn't allow me to place the files in the zip.
    07-23-2012 01:06 PM
  2. nitestalkr's Avatar
    What zip manager are you using?
    07-23-2012 01:11 PM
  3. andrewnelson23's Avatar
    I was just using my documents folders. lol. Do I have to extract the rom first, or is that what you meant by do not unzip?
    07-23-2012 01:13 PM
  4. sammyz's Avatar
    Do not unzip the rom....meaning do not extract it.
    nitestalkr likes this.
    07-23-2012 01:31 PM
  5. nitestalkr's Avatar
    Thanks for explaining that.
    And if you do choose to unzip(extract) and want to zip it back up(make it a zip file again) you would need to change the compression method to 'Store' instead of 'Compress'. Sammyz and I discovered this when making our boot animations. But its just easier to NOT extract the zip, and to just open the zip folder with winRAR, 7zip, izarc (I use this), or any other compression software, and copy the needed files from the fix.zip(this zip can be extracted) and replace the ones in the ROM.zip(DO NOT EXTRACT THIS).
    07-23-2012 01:53 PM
  6. Nate456's Avatar
    Use 7zip it's like duct tape for rom flashing.
    Sent from my shole using Tapatalk 2
    07-23-2012 01:53 PM
  7. cole2kb's Avatar
    Open the zip file in 7zip. In that application, you can navigate files just like a folder. Delete the old files, replace them with the new ones, it will be saved automatically. Turn off signature verification before you flash. Simple as that.
    I do this when I replace launchers in ROMs before I flash, or if I want to get inverted GApps going with less steps. Works great.
    edit -- Nate ninja'ed me, haha.
    07-23-2012 01:53 PM
  8. nitestalkr's Avatar
    I ninja'd both of you. xD
    cole2kb and andrewnelson23 like this.
    07-23-2012 01:55 PM
  9. sammyz's Avatar
    No, NEVER extract and rezip an entire ROM, you break stuff by doing that. There are files you just cannot see while in windows. A bootanimation you can, but a ROM this is a NO-NO
    andrewnelson23 likes this.
    07-23-2012 02:02 PM
  10. nitestalkr's Avatar
    Its just not safe to repackage a ROM that way, I've done it to a few times, there were only a few incidents where the ROM broke.
    07-23-2012 02:10 PM
  11. sammyz's Avatar
    Each time I've done it I got status 0 error
    Also a guide is up to get this phone on ZVJ, if anyone here is interested.
    http://forums.androidcentral.com/opt...mus-v-zvj.html
    I hear you all found a way to get it on ZVD
    07-23-2012 02:13 PM
  12. JussCallMeUno's Avatar
    Ummmm this is really awesome!!! I've noticed something though, the sounds not working I don't know if the phone speaker works as mine broke while in Alpha CM9, but I know plugging speakers in or headphones don't work. Is there any fix for this!?!?!? Thanks
    Have you tried this?.. It might work
    http://forum.xda-developers.com/showthread.php?t=1783993
    StumDroid and clodfelterac like this.
    07-23-2012 02:14 PM
  13. nitestalkr's Avatar
    I hear you found a way to get it on ZVD
    Not me, but Zakman did.
    I'm just helping people out getting it to work since I'm available 24/7
    07-23-2012 02:20 PM
  14. sammyz's Avatar
    I meant you all.....
    07-23-2012 02:41 PM
  15. StumDroid's Avatar
    Ummmm I tried and no sound on headphones still.... should I stick the file in the ROM itself on Windows then install it? Like how the data is done? Thanks for the help!
    Sent from my LG-LS670 using Android Central Forums
    07-23-2012 04:39 PM
  16. nitestalkr's Avatar
    Yea, unless its a flash able zip, its always best to stick it into the rom before flashing.
    If it still doesn't work, then wait for another fix. JB is still extremely early alpha, so be patient.
    07-23-2012 04:59 PM
  17. StumDroid's Avatar
    Thanks for the quick reply! I will try here soon and let you know how it goes! I'm patient, just love this Jelly Bean and would love to listen to my music. All the devs on this are crazy and I'm very thankful for all their hard work. Thanks for the help and info you've provided for me
    Edit: Did not work, no biggie. Guess that's why I have an MP3 player
    07-23-2012 07:13 PM
  18. nitestalkr's Avatar
    No problem, any time.
    I'm waiting until a ROM is officially built with the ZVD and sound lib fixes and released by a dev before I start testing for myself, till then, I will just provide information and help out those in need. After all, I'm available practically 24/7 on the forums through tapatalk.
    StumDroid likes this.
    07-23-2012 07:21 PM
  19. StumDroid's Avatar
    Would I be able to pull the Libs and or other files out of a working ROM like Quattrimus Cm9? If its possible could u provide me with what files I will need to pull from cm9? I also seen that someone is working on this same ROM for ZVD (vm670) and it won't boot in, but could the sound files on that work possibly or are they the same as the ones I currently have?
    07-23-2012 10:19 PM
  20. nitestalkr's Avatar
    No, using libs from android 4.0.4 on Android 4.1 could cause problems, devs have experienced this when trying to use files from a froyo rom, to get a GB rom working. Same with GB onto ICS. JB will require JB libs. So unless you find a JB rom for LG Optimus S/U/V that contains the necessary files, you're out of luck.
    07-24-2012 02:36 AM
  21. Zakman's Avatar
    So the libs have to be custom made or the kernal modified to fix the issues.
    07-24-2012 02:40 AM
  22. nitestalkr's Avatar
    To my knowledge, you are correct. It's most likely a kernel issue, since its still using a Ginger Kernel variant. We still dont have our own ICS kernel built yet. If its not a kernel issue, then its an issue with the source, missing needed files. Either way, only time will tell when we get working sound on JB, all we can do is be patient, or hit the books and figure out how to fix this, without forward porting (which 97% of the time, never works).
    flapjack.fiasco likes this.
    07-24-2012 03:09 AM
  23. StumDroid's Avatar
    Ummmm so how'd they get it working on 4.0.4? Just curious if you know or not.
    07-24-2012 10:12 AM
  24. Zakman's Avatar
    Tdm and thekraven put in much time and effort with making there own kernels and building from source.
    07-24-2012 11:42 AM
  25. StumDroid's Avatar
    Oh OK. So how do you build your own kernels and such? I've always been curious, I would really like to get into that process, I'm very good with computers and such, but never looked into how to build kernels and such, even being able to port a ROM over would be awesome.
    Edit: Sorry I realize I'm getting a bit off topic. Any links you guys can give me? So I don't get off topic on here
    07-24-2012 12:09 PM
487 ... 56789 ...
