04-19-2013 12:12 AM
487 ... 7891011 ...
tools
  1. StumDroid's Avatar
    Thanks a ton!!! I'll try right now! You are the man! :thumbup:
    Quick question, u said paste into a folder then paste it in the ROM, the whole folder or the files individually?
    Sent from my LG-LS670 using Android Central Forums
    07-25-2012 12:29 AM
  2. nitestalkr's Avatar
    If it works, I'll package it all(including zakman's fix) in a flashable zip for everyone.
    sent from my un-dead sammich.
    inceyet likes this.
    07-25-2012 12:32 AM
  3. andrewnelson23's Avatar
    This zip should include a key switch
    07-25-2012 12:36 AM
  4. StumDroid's Avatar
    Sweet I will tell u how it goes
    07-25-2012 12:37 AM
  5. nitestalkr's Avatar
    I will search for the appropriate files, and include them as well, if everything goes smoothly.
    andrewnelson23 likes this.
    07-25-2012 12:44 AM
  6. exProphecy's Avatar
    So wait we need to be ZVJ or ZVD to try this out? Cuz I'm ZV4.. >_<
    07-25-2012 12:47 AM
  7. andrewnelson23's Avatar
    I'm zv9 and I replaced the appropriate files in the rom(the zvd-fix) and it booted and everything worked. nandroid and try
    07-25-2012 12:49 AM
  8. nitestalkr's Avatar
    If my potential sound fix works, I will package the zvd fix, button mapping fix, and sound fix in a flashable zip for everyone, so less advanced users can easily flash jelly bean on the V without needing to modify the ROM before flashing.
    07-25-2012 12:51 AM
  9. andrewnelson23's Avatar
    i think he meant just cm10 in general
    07-25-2012 12:53 AM
  10. nitestalkr's Avatar
    Either way, my flashable zip SHOULD work abs make everything smoother when flashing, for this specific rom.
    And CM10 only requires an android phone.
    07-25-2012 12:57 AM
  11. Nate456's Avatar
    If you don't know what ZV(x) you need to be on then you might need to wait for one of the OV devs to make it.
    Sent from my shole using Tapatalk 2
    07-25-2012 01:00 AM
  12. andrewnelson23's Avatar
    while you're at it, in the zip you should include the free jelly beans
    07-25-2012 01:00 AM
  13. nitestalkr's Avatar
    The Optimus V is ZVD only. The ZV4, ZV5, and ZV9, are all branches of ZVD. ZVD is Froyo firmware, and since the V only comes in Froyo(stock), it uses ZVD, the numbers are just Virgin Mobiles versions of ZVD.
    ZVJ is LG Optimus S firmware for stock gingerbread.
    exProphecy likes this.
    07-25-2012 01:06 AM
  14. nitestalkr's Avatar
    I'll probably end up packaging everything into JB gapps, for simplicity of flashing
    07-25-2012 01:07 AM
  15. andrewnelson23's Avatar
    NOT ANYMORE IT ISN'T THANKS TO SAMMYZ! Fully functional ZVJ firmware for the Optimus V.
    sammyz likes this.
    07-25-2012 01:10 AM
  16. flapjack.fiasco's Avatar
    Is that kosher? I know that the devs for all the OV ROMs have removed gapps from their ROMs, due to Google's legal requirements. I know that there are versions of gapps that are slimmed down, but is it legal to add things?
    07-25-2012 01:12 AM
  17. nitestalkr's Avatar
    I was talking about Out of the Box Lg Optimus V
    And, until sammyz finds a waaaaaaaay simpler way to get ZVJ on the V, I'm sticking to ZVD/ZV4
    07-25-2012 01:14 AM
  18. andrewnelson23's Avatar
    Yeahhh hahah it is a VERY complicated method.
    07-25-2012 01:16 AM
  19. nitestalkr's Avatar
    Well, it's only questionably illegal to include Gapps into ROMs, but altering gapps is perfectly fine I'm certain. If anyone thinks I shouldn't include Gapps in the fix zip, then I will keep it separate.
    07-25-2012 01:16 AM
  20. Nate456's Avatar
    Yes, yes it is. I just left mine at stock rooted GingerBread.
    07-25-2012 01:20 AM
  21. andrewnelson23's Avatar
    07-25-2012 01:29 AM
  22. nitestalkr's Avatar
    Is there still a data issue with Jelly Bean on the V??
    Ok, I believe I have all of the potential Fixes that i mentioned that i'd make into a flash able .zip...
    About to package it, and possibly test it.
    07-25-2012 01:41 AM
  23. andrewnelson23's Avatar
    I'm not entirely sure, but I don't think so. I think zakman's files fixed it. I booted today and made some calls and texts, but I didn't bother to try data because I live in such an awful service area. I could try tomorrow though
    And if there is an issue with it, there's always switching over to zvj
    nitestalkr and sammyz like this.
    07-25-2012 01:49 AM
  24. YoshinJaa's Avatar
    As far as I know, data works after replacing the 3 .so files
    nitestalkr likes this.
    07-25-2012 01:49 AM
  25. sellers86's Avatar
    Well, it's only questionably illegal to include Gapps into ROMs.
    No, its completely illegal. Not questionably. It is illegal, unless based on a stock rom like harmonia. Its Google liscences and copyrights.
    flapjack.fiasco likes this.
    07-25-2012 01:50 AM
487 ... 7891011 ...
