Zakman
To fix color banding use the same 3 files from quatrimus aokp beta 1.
Which three files are you talking about?
Sent from my LG-LS670 using Android Central Forums
Oh OK. So how do you build your own kernels and such? I've always been curious, I would really like to get into that process, I'm very good with computers and such, but never looked into how to build kernels and such, even being able to port a ROM over would be awesome.
Look back a few pages.
Sent from my shole using Tapatalk 2
Do you have any experience using Linux, writing code in c++, coding in cs, Java codex, writing code in general?
Everything android is based on Linux codec, I suggest studying up on the above subjects before trying your hand in making kernels. (Study Linux Kernel development)
sent from my un-dead sammich.
Thanks! I have used Linux a few times here and there. I have tried writing codes years ago when I was a "noob" but I will defiently start back up and get somewhere with it this time around Thanks a ton for telling me where to start! Much appreciated.
In system/lib/ replace libgstk_exp.so, libpbmlib.so, libwms.so with these: fix_zvd.zip
I looked and I don't see it......maybe I'm blind lol, which page is it on?
Isn't that just a fix for network? Lol I thought it said Color Banding? "The 3 files from quatrimus beta 1" I had thought that meant like how the visuals is messed up a little like on the wallpaper
Those are the only 3 files in a list that i could find, maybe he's using the same files, but from quattrimus??
Well if the network fix works and their from quatrimus beta 1, couldnt like stuff like a headphone fix work too? No speakers cause it blew while on Alpha 10 of CM9 and the headphones the only way I can listen to music and my games.... bugs me a bit but can't keep me off 4.1 lol, i was shocked when I heard 4.0 was running on our phones and we already have some Jelly Bean big ups to all devs out their and anyone else that helped even in the smallest of ways, you guys are amazing!
Thanks! I will try ASAP, what would the files be for the headphones?
