capslock118
Re: Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean
Does MMS != SMS? because the latter is working for me just fine.
well I can make/receive calls, send text messages, and go online, that's why I was asking because whatever MMS is, apparently I must not use it
looks like tethering isn't working (thought i read previously that it did). I go to activate it and it just sits in what i'll call "prepping mode".
headphones work. I don't have bluetooth devices (unless i can somehow tether my nexus 7 to my phone?) and i don't have a mic to test either.
can't seem to find the setting (might be a CM setting) to install all apps to sd. So i am having trouble getting everything in given how little space there is available on the internal memory. that's a small issue really, as long as calls and texting works i'm good to keep this around to keep testing it
i can't believe how smooth everything is.
Remember, CM10 Jelly Bean is still in EARLY alpha stage, so a lot of things wont be working, and cannot be fixed yet. Heck, even in ICS we dont have tethering woring natively..
BUT in both ICS and JB, we can use an app to use for tethering.
And once i have tdm's permission, i WILL include the SD-ext script that he uses, but this will require you to partition up to 1GB(max) for expanded app space.
Don't get me wrong, I am well aware of that. I was just posting my initial experience. Like I said as long as the actual phone part works, texting, and data, I am thrilled to keep working with it and letting you know of any issues I find myself.
I'll check that app out.
Aside from backups which I dump onto my pc anyways, that would not be a problem for me. I am guessing here that not just any apps can be dumped in here? In other words, the only things I use my SD card for anyways is storing apps.
Woah, Jelly Bean already available for our beloved Optimus V!? Color me impressed.
I'm on ZV4 baseband, can I still flash this??? I just want Wifi working, as my OV has long since been out of service.
Follow my guide in the second post. Wifi works.
sent from my un-dead sammich.
In case anyone is interested:
I use titanium backup. It defaults to restoring apps and data to internal memory even though my apps and data were on the SD card when I took my backups. The end result was that, to restore all of my apps, I had to restore in multiple batches. Restore some, move those to SD card, and repeat until finished.
Link2sd was pretty good moving everything but itself and the play store.
I should also point out how the display looks I fill it, I'm not sure if this is what is called 'banding':
With the sd-ext script that tdm has, every app that you download, install, and use on the phone(other than built in system apps) will be automagically moved to the sd-ext partition, along with the apps cache.
i can't remember what app others were talking about(its mentioned somewhere in this thread) but i do suggest it for a temporary Wifi tethering fix.
I'm done porting. I either have service and banding or I have no service and no banding. wtf.
Well i used Drews jb and put the zvd files in and i tried to port a p500 jb rom and i get no service. but no banding with drews i get banding
Well the thing is I need a list of files that I know are for the radio so I can port them from drews to the p500 rom I have
