1. kingson60's Avatar
    my name frank and i love my lg optimus v but my problem is that i did factory resect but i did not back up and now when i plug the phone up the clockworkmod recovery v5.0.2.7 come on and stay on and i am not getting any action so help please thanks
    07-21-2012 11:55 PM
  2. flapjack.fiasco's Avatar
    Tell us exactly what you can do. There's not a lot of info to go from in your post. Are you trying to flash a custom ROM?
    07-22-2012 12:25 PM
  3. AndyOpie150's Avatar
    If you have a recovery menu that allows you to scroll and select options then try flashing the Xionia v1.2518.6 in it's zipped form just like you would if it was a ROM then going into the advanced section and selecting reboot recovery. Then in the Xionia recovery go to the advanced section and select the "fix recovery loop option"
    The most informative Guide can be found here: http://androidforums.com/optimus-v-a...ted-phone.html
    flapjack.fiasco likes this.
    07-23-2012 03:36 AM
