08-02-2012 10:34 PM
168 1234 ...
tools
  1. asadullah's Avatar
    You may have to flash the zvh radio with this it's pretty simple throw the radio in the root of the zip and add this to the update script
    Code:
    write_firmware_image("PACKAGE:radio.img", "radio");
    right aboe this
    Code:
    show_progress(0.500000, 0);
    unmount("/system");
    07-22-2012 07:05 PM
  2. jonny5449's Avatar
    Code:
    right aboe this
    Code:
    unmount("/system");
    I'm just agreeing lol yup
    Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
    07-22-2012 07:07 PM
  3. sammyz's Avatar
    That's an easy fix as assadullah says
    Ik its an easy fix, I just want to know if it should be LS670 or VM670......Once you flash this firmware, you are actually holding an optimus S......root methods are different, radio is flashed to an optimus s radio .....the phone is an optimus s with virgin mobile written on the top of the phone and a sprint bootanimation.
    Sent from my Optimus M
    07-22-2012 07:08 PM
  4. sammyz's Avatar
    Code:
    right aboe this
    Code:
    unmount("/system");
    Why you going on ZVH? ZVJ is downloaded via OTA once you get data working.
    07-22-2012 07:14 PM
  5. jonny5449's Avatar
    Can't root unless your coming from a rooted zvd so be careful
    07-22-2012 07:15 PM
  6. sammyz's Avatar
    Awww crap, I have ZVD in my PC I used ZVD to get to OS firmware, I have to downgrade when I get home though....
    07-22-2012 07:18 PM
  7. asadullah's Avatar
    No I just put the zvh radio in there unless there's a zvj radio I missed (didn't look ) I flashed the rom and definitely need the new radio
    07-22-2012 07:18 PM
  8. ThatGuyLurkin's Avatar
    But you can still root using a Computer, cant you?
    07-22-2012 07:18 PM
  9. sammyz's Avatar
    ZVJ has a radio yes. My ov works fine with it.
    07-22-2012 07:22 PM
  10. jonny5449's Avatar
    Yes but it is Manuel useing zvh stock recovery if you need thread I shall digit up
    07-22-2012 07:23 PM
  11. sammyz's Avatar
    I hope so, someone tell us if there is any root method for ZVJ please. Without having to downgrade to ZVD
    07-22-2012 07:24 PM
  12. Zhara's Avatar
    Not without having to downgrade to zvd or zvh, no.
    07-22-2012 07:25 PM
  13. jonny5449's Avatar
    You have too because you need stock zvh recovery to root which can not be obtained without root
    07-22-2012 07:25 PM
  14. sammyz's Avatar
    Alrighty then, down to ZVD it is, when I get home at 10 or later ....
    07-22-2012 07:27 PM
  15. sellers86's Avatar
    I have zvh update but I can't remember if it is gingerbread or not?? But if there is a already deodexed zvj me wants that
    Its gb but there were a lot of problems with it
    Sent from my VM670 using Tapatalk
    07-22-2012 07:30 PM
  16. jonny5449's Avatar
    I will gladly dig up thread for rooting zvj same Manuel thing as zvh
    07-22-2012 07:42 PM
  17. Zhara's Avatar
    http://forums.androidcentral.com/sho...d.php?t=166929
    Just cause I wanna beat you to it, johnny
    sammyz likes this.
    07-22-2012 07:51 PM
  18. asadullah's Avatar
    Well I'm disappointed in two things right now:
    1) Jerryscripts green recovery doesn't properly flash a radio or at least this version doesn't
    2) the movie mission to mars led me to believe that there would be some fighting with aliens going on when they killed those astronauts but then nothing happenend it was the exact opposite they get there and the aliens had a puzzle and ..... well I was disappointed
    07-22-2012 07:57 PM
  19. Nate456's Avatar
    Spoiler Alert
    According to the movie we're of Martian descent and one guy stayed in the ship and ended up going to the planet the Martians are living on.
    07-22-2012 08:03 PM
  20. jonny5449's Avatar
    Lucky had to eat dinner
    07-22-2012 08:04 PM
  21. sammyz's Avatar
    You are on optimus s firmware, you have an optimus s in your hands now, not an optimus v, go get an optimus s recovery :P
    Edit: finally on wifi
    Still no PC, not home.
    07-22-2012 08:09 PM
  22. jonny5449's Avatar
    Yes
    07-22-2012 08:10 PM
  23. andrewnelson23's Avatar
    So, to slow things out and condense everything, basically,
    We will change to zvj. Then we have to revert to zvd in order to root. Then we have to get the zvj recovery and we can update and root from that? And then we can flash the zvj roms?
    Yeah?
    This sounds insanely complicated. BUT I'M PUMPED.
    07-22-2012 08:11 PM
  24. sammyz's Avatar
    Yeah?
    No you will start from ZVD and then root ZVJ
    07-22-2012 08:12 PM
  25. asadullah's Avatar
    Spoiler Alert
    Lol
    @sammyz
    Wish I wouldve know that before I started flashing this zvd cab it's alright jsut sets things back some
    07-22-2012 08:16 PM
168 1234 ...
