08-02-2012 10:34 PM
168 12345 ...
tools
  1. andrewnelson23's Avatar
    No you will start from ZVD and then root ZVJ
    Sent from my Optimus M
    Oh okay, so you're new guide will show how to install optimus s firmware with the zvd radio.
    07-22-2012 08:16 PM
  2. sammyz's Avatar
    Yes and then root with whichever guide works for me up to ZVJ
    07-22-2012 08:20 PM
  3. andrewnelson23's Avatar
    That automated root one looked good, but I noticed it installed xionia recovery. Which could potentially be bad if it's an old xionia that isn't compatible with the newer screens. Right?
    07-22-2012 08:26 PM
  4. sammyz's Avatar
    Replace it with another recovery if you find anything better...make sure its an optimus s recovery.
    07-22-2012 08:27 PM
  5. andrewnelson23's Avatar
    It's automated. When you click the root button, it installs root, busybox and xionia.
    07-22-2012 08:29 PM
  6. sammyz's Avatar
    Is it a .bat?
    07-22-2012 08:37 PM
  7. Nate456's Avatar
    The OVs with the new screen are using the Optimus S screen so xionia should work.
    andrewnelson23 likes this.
    07-22-2012 08:42 PM
  8. andrewnelson23's Avatar
    Is it a .bat?
    I don't know haha didn't download it yet.
    For installing zvd, would you just open kp500, enter LS670, and then enter the zvd cab? Where is the zvd cab at?
    07-22-2012 08:49 PM
  9. sammyz's Avatar
    No, you will need the bin, you will lose AAA/HA keys so back them up. You use LGNPST, my battery is gonna die.
    07-22-2012 08:52 PM
  10. asadullah's Avatar
    "What you doing asad"? "Oh just sending 149 zerglings" LMAO
    07-22-2012 08:54 PM
  11. andrewnelson23's Avatar
    Ohhhhh. Maybe I'll just wait for your guide. But I do have all of my wireless info saved on my computer, back from when I bricked in April and had to unbrick using s firmware
    07-22-2012 08:57 PM
  12. cammykool's Avatar
    So that. Would pretty mc make my v an s and j can't flash opt is v Roms. Just opt us s?
    07-22-2012 09:08 PM
  13. asadullah's Avatar
    What I do is get everything to run correctly in dfs to show my ha aaa keys and use snip tool to take screen shots of everything (including the hex version) and then go into qpst and backup to file. Then basically just use dfs to write and the backup and then use the qpst backup (overkill)
    Sidenote got the zvj rooted deodexed to work now using the zvh radio now for that menu home button thing
    07-22-2012 09:11 PM
  14. andrewnelson23's Avatar
    i already backed up my spc, my nai, my home address, my prim ha address, and my sec ha address, my aaa hex, and my ha hex. i just copied all of them and made a document with all of them. is that right?
    07-22-2012 09:20 PM
  15. asadullah's Avatar
    Pretty much
    So I got the buttons switched easily just go into the zvj update zip and navigate to system/usr/keylayout and open up thunderkeypad.kl erase everything and copy this in it's place
    Code:
    key 2     1
    key 3     2
    key 4     3
    key 5     4
    key 6     5
    key 7     6
    key 8     7
    key 9     8
    key 10    9
    key 11    0
    key 158   BACK              WAKE_DROPPED
    key 230   MENU              WAKE
    key 60    SOFT_RIGHT        WAKE
    key 62    ENDCALL           WAKE_DROPPED
    key 229   HOME         WAKE_DROPPED
    key 59    HOME         WAKE_DROPPED
    key 139   HOME              WAKE_DROPPED
    key 228   POUND
    key 227   STAR
    key 231   CALL              WAKE_DROPPED
    key 61    CALL              WAKE_DROPPED
    key 232   DPAD_CENTER       WAKE_DROPPED
    key 108   DPAD_DOWN         WAKE_DROPPED
    key 103   DPAD_UP           WAKE_DROPPED
    #key 102   ENDCALL           WAKE_DROPPED
    key 102   MENU              WAKE
    key 105   DPAD_LEFT         WAKE_DROPPED
    key 106   DPAD_RIGHT        WAKE_DROPPED
    key 115   VOLUME_UP         WAKE
    key 114   VOLUME_DOWN       WAKE
    key 213   DEL               WAKE_DROPPED
    key 355   DEL               WAKE_DROPPED
    key 212   CAMERA
    key 247   FOCUS
    key 217   SEARCH            WAKE_DROPPED
    # LGSI_LS670_FroyoToGB_Keypad_Initialization_Vivek_15Apr2011_START
    key 216   VOICE
    # LGSI_LS670_FroyoToGB_Keypad_Initialization_Vivek_15Apr2011_END
    key 226   HEADSETHOOK       WAKE
    key 116   POWER             WAKE
    key 107   ENDCALL           WAKE_DROPPED
    key 16    Q
    key 17    W
    key 18    E
    key 19    R
    key 20    T
    key 21    Y
    key 22    U
    key 23    I
    key 24    O
    key 25    P
    key 30    A
    key 31    S
    key 32    D
    key 33    F
    key 34    G
    key 35    H
    key 36    J
    key 37    K
    key 38    L
    key 14    DEL
    key 44    Z
    key 45    X
    key 46    C
    key 47    V
    key 48    B
    key 49    N
    key 50    M
    key 51    COMMA
    key 52    PERIOD
    key 28    ENTER
    key 56    ALT_LEFT
    key 42    SHIFT_LEFT
    key 215   AT
    key 57    SPACE
    key 53    SLASH
    key 127   SYM
    key 100   ALT_RIGHT
    key 399   GRAVE
    save open up command prompt and type
    Code:
    adb remount
    adb push thunderkeypad.kl /system/usr/keylayout
    adb reboot
    If your on your phone just open up the file with es note editor and change all the spots that say menu to home and vice-versa
    07-22-2012 09:33 PM
  16. andrewnelson23's Avatar
    I think you're way ahead of anyone. haha. I don't even know how to change firmwares to zvd.
    07-22-2012 09:45 PM
  17. asadullah's Avatar
    What I did was go here and download the zvd cab and follow the guide sammy wrote except switch vm670 with ls670 and zvc with zvd almost forgot place the zvh update zip on your sdcard renamed as update.zip that way when you get done running kp500 you reboot to recovery (don't forget the menu and home keys are switched) wipe data /cache and then choose run update.zip
    07-22-2012 09:53 PM
  18. andrewnelson23's Avatar
    Why did you go to zvh? I thought the ultimate goal was to get zvj?
    Edit: ohhhh, you couldn't find the zvj update anywhere? welll, I found it: Go here. Second post, D11.
    07-22-2012 09:58 PM
  19. asadullah's Avatar
    My bad I left that part out. Once I got to zvh I used optiauto to root install a custom recocvery and installed the zvj deodexed rom
    07-22-2012 10:18 PM
  20. andrewnelson23's Avatar
    so what was the point of lgnpst?
    07-22-2012 10:20 PM
  21. asadullah's Avatar
    When you flash the sprint software you lose 3g data so you have to rewrite some settings using lgnpst to give your pc the ability to read and write aaa and ha passwords
    07-22-2012 10:28 PM
  22. andrewnelson23's Avatar
    Gotcha!!! I think I'm gonna try it out. making backup of everything and putting it on my computer first. then I can always recover using sammyz guide for zv5 if something goes wrong.
    quick outline of what i'll do:
    download the zvd cab. switch vm670 with ls670. use zvd instead of zv5. then wait for it to work. then root using that automated method and update to zvj. Then use lgnpst to fix the data? (I've done that before)
    07-22-2012 10:36 PM
  23. asadullah's Avatar
    I would wait
    sammyz likes this.
    07-22-2012 10:37 PM
  24. jonny5449's Avatar
    I would wait also
    Sent From My LS670
    07-22-2012 10:41 PM
  25. andrewnelson23's Avatar
    Okay I'll wait. just found out I don't have to work tomorrow
    07-22-2012 10:43 PM
168 12345 ...
