08-02-2012 10:34 PM
168 ... 23456 ...
tools
  1. jonny5449's Avatar
    Okay I'll wait. just found out I don't have to work tomorrow
    That's a good thing glad your off
    Sent From My LS670
    andrewnelson23 likes this.
    07-22-2012 10:49 PM
  2. sammyz's Avatar
    This is not my tablet in signature, please wait for the guide, you will save yourself a lot of time and stress if you wait.
    Sent from my Ainol Novo8 Advanced using Android Central Forums
    07-22-2012 11:38 PM
  3. sammyz's Avatar
    You will use LGNPST for the ENTIRE process of getting from OV fw to OS ZVD and getting data to work. It is noob proof to where there is no way to screw your phone. But it will be a long detailed guide.
    Sent from my Optimus M
    07-22-2012 11:53 PM
  4. ThatGuyLurkin's Avatar
    Correct me if I'm wrong, so when you post this guide, I can use stuff like Hydro Rom? Or stock?
    07-23-2012 12:18 AM
  5. sellers86's Avatar
    yes.
    07-23-2012 12:30 AM
  6. Phatninja55's Avatar
    I still think that there is a slight chance that this baseband will not work with virgin mobile, I've talked to Sammyz12 about this, and I plan on testing it before he releases his guide.
    07-23-2012 02:35 AM
  7. asadullah's Avatar
    The zvh radio works good i haven't tested the zvj radio yet. That damn lgnpst 1.3 has screwed up my windows partition so i gotta wipe and reflash it. Really wish it had a factory data reset.
    07-23-2012 06:52 AM
  8. jonny5449's Avatar
    After this all you gotta do is take the home and menu button out and switch them around to have an optimus s
    Your optimistic v has reached the impossible its running on metro pcs and running s firmware I'm amazed
    Sent From My LS670
    07-23-2012 07:47 AM
  9. thewraith420's Avatar
    Sweet! I've been playing with this idea since we got our zv9 update . zip as a way back to vm! The most I managed to get working is zvh with calling and sms. Sammyz done it again with another breakthrough! Who else runs an optimus v that thinks it's an s but connects to metropcs lol
    07-23-2012 08:47 AM
  10. sammyz's Avatar
    Lol this^^^^
    07-23-2012 09:56 AM
  11. sammyz's Avatar
    Sent From My LS670
    Lol, my optimus m is actually running optimus c firmware too...lol
    07-23-2012 09:58 AM
  12. jonny5449's Avatar
    oh thats a whole other story lol
    i could port a rom for your guys zvj
    Sent From My LS670
    07-23-2012 10:21 AM
  13. sammyz's Avatar
    Sent From My LS670
    OM and OC don't have ZVJ
    07-23-2012 10:23 AM
  14. andrewnelson23's Avatar
    He's optimus s :P he's offering to port os zvj roms to ov zvj I'm really pumped for your guide btw! I saw a vm fix in the other thread, but I don't really understand what it does or how to do it.
    07-23-2012 10:38 AM
  15. sammyz's Avatar
    You replace the fles from the zip into the download you get from the optimus S forum
    07-23-2012 10:39 AM
  16. ThatGuyLurkin's Avatar
    ZVJ roms are based on stock, which wouldn't be easy to port. Idk about Sammyz and his Radio bricking and hacking. I'm still confused.
    07-23-2012 10:43 AM
  17. andrewnelson23's Avatar
    the cm10 zvj port is not a stock rom...
    07-23-2012 11:42 AM
  18. andrewnelson23's Avatar
    can you do that in windows? or would i have to boot into ubuntu to do that. thought it might mess things up using windows.
    07-23-2012 11:43 AM
  19. ThatGuyLurkin's Avatar
    That's A ZVJ rom that's already been solved to ZVD. Meaning, there's no point in porting.
    07-23-2012 11:47 AM
  20. andrewnelson23's Avatar
    that was just an example :P haha but okay. Yeah I don't know what optimus s zvj roms there are. but I just want it for jb
    07-23-2012 12:00 PM
  21. ThatGuyLurkin's Avatar
    Go get it xD. There's a ZVD fix meaning data works on the V.
    07-23-2012 12:22 PM
  22. sammyz's Avatar
    07-23-2012 12:39 PM
  23. sammyz's Avatar
    Now that we have this guide, anyone else going to port some ZVJ roms?
    Sent from my Optimus V running Optimus S firmware on MetroPCS
    07-23-2012 06:35 PM
  24. cole2kb's Avatar
    Are the files that you replace in the same location throughout all ROMs?
    07-23-2012 06:53 PM
  25. sammyz's Avatar
    I'm not sure, I haven't been able to mess with much, I'm still on ZVD....family is visiting, that's why it took me so long to put the guide up....
    07-23-2012 06:56 PM
168 ... 23456 ...
