08-02-2012 09:34 PM
168 ... 34567
tools
  1. cole2kb's Avatar
    Okay, so, it seems logical to think that they will be in the same place, although dependent on OS versions.
    So, Froyo goes in one place, Gingerbread goes in another, and ICS goes in another, and Jellybean goes in another. If that is the case, and someone will need to research this, shouldn't take too long, then it would make much more sense to not "port" every ZVJ ROM, make a new tread, and commit to supporting it, and just create three flashable ZIPs, one for each OS, with the files being replaced, and instructing users on how to fix MMS by using GoSMS, unless that is as easy as replacing the files to fix the radio, and not independent of what ROM you're working off of.
    07-23-2012 06:02 PM
  2. ThatGuyLurkin's Avatar
    There's really no point of making a thread, yes. Drew, and everyone else already made it. So it's kinda like posting in the wrong forums.
    I'm gonna do alot if testing. I can't stand the GO apps. To nuch bloat.
    07-23-2012 06:08 PM
  3. cole2kb's Avatar
    Bloated, yeah, but I notice no difference between using GoSMS and the stock messaging app in terms of performance. They used to have more options for hiding the GoBloat, but it's pretty much unavoidable now.
    07-23-2012 06:13 PM
  4. ThatGuyLurkin's Avatar
    Hopefully it's not to hard. And by making 3 flashable zips, what do you mean?
    07-23-2012 06:21 PM
  5. Nate456's Avatar
    Maybe by making 3 flashable MMS fixxes.
    07-23-2012 06:25 PM
  6. sammyz's Avatar
    I already said to post ported ROMs in this thread....
    Sent from my Optimus V running Optimus S firmware on MetroPCS
    07-23-2012 06:40 PM
  7. Phatninja55's Avatar
    Anybody fix the home button and menu button yet? My ocd may make me switch back to ov firmware.
    07-26-2012 12:03 AM
  8. thewraith420's Avatar
    Keys 102 and 139 need to be switched in qwerty.kl and thunderc_keypad.kl
    System/usr/keypad/
    Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
    07-26-2012 12:07 AM
  9. Phatninja55's Avatar
    System/usr/keypad/
    Nvm. I fixed that before you posted xD
    07-26-2012 12:57 AM
  10. thewraith420's Avatar
    So.... Jonny5449.... Any news on a ov zvj rom? Lol let me know I'd be glad to test
    07-26-2012 07:39 AM
  11. sammyz's Avatar
    So.... Johnny.... Any news on a ov zvj rom? Lol
    I was wondering the same thing
    Sent from my Optimus M
    07-26-2012 07:40 AM
  12. thewraith420's Avatar
    Dangit lol you ninja'd my edit
    07-26-2012 07:44 AM
  13. sammyz's Avatar
    I just saw that lol
    07-26-2012 07:49 AM
  14. sammyz's Avatar
    Wondering and wanting to test as well
    07-26-2012 07:50 AM
  15. andrewnelson23's Avatar
    So...where are we at regarding all of the zvj/zvd radios and methods?
    With Nitestalkr's method, we have:
    zvj roms with everything working but mms except for gingerbread roms, in which data still doesn't work?
    With Sammyz method, we have:
    zvd roms with everything working, except mms won't work on the stock rom?
    zvj roms with everything working, except mms won't work on the stock rom?
    Or am I way off? Maybe someone else could explain it better.
    07-26-2012 08:59 AM
  16. sammyz's Avatar
    GB/ICS/JB ZVJ will all work with this for data, GB won't work with data with nitestalkr's method and MMS is in the works for both.
    nitestalkr likes this.
    07-26-2012 09:21 AM
  17. thewraith420's Avatar
    ^^^what he said. Basically we've got the radio working perfectly. Just need a rom for the V with proper mms settings.
    07-26-2012 03:02 PM
  18. thewraith420's Avatar
    You know... Porting aside I think someone could now build stock based gb roms from source.. Something that has been just about impossible till now due to no zvj radio.
    07-26-2012 03:29 PM
  19. sammyz's Avatar
    Ummm there is one on the Optimus S forum.
    Just needs MMS fix made. And key switch.
    07-26-2012 04:32 PM
  20. ThatGuyLurkin's Avatar
    1. How would you even make a OV ZVJ rom....?
    2. Don't have the sources for a pure GB rom with VM's sources. :/
    07-26-2012 04:56 PM
  21. sellers86's Avatar
    Red baron did it. Not for zvj though. And tdm did it with ics.
    07-26-2012 05:24 PM
  22. thewraith420's Avatar
    It would have to be from Sprint sources with mms settings for vm and keypad fixed for the V
    07-26-2012 05:45 PM
  23. sammyz's Avatar
    @ThatGuyLurking
    http://forums.androidcentral.com/lg-...-rom-base.html
    Stock ZVJ Rooted ROM^ must be on ZVJ firmware.
    07-26-2012 06:02 PM
  24. thewraith420's Avatar
    I just mean if we got source for any of the zvj roms a rom for optimus v zvj should be able to be hammered out without too much trouble.
    07-26-2012 06:34 PM
  25. sammyz's Avatar
    How do they build zvj based roms if they don't have source?
    07-26-2012 06:42 PM
168 ... 34567
