08-02-2012 09:34 PM
168 ... 4567
tools
  1. nitestalkr's Avatar
    I just mean if we got source for any of the zvj roms a rom for optimus v zvj should be able to be hammered out without too much trouble.
    Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
    Using GitHub...
    If someone copied everything used to build a Optimus S ZVJ GB Rom, and edited the newly copied source, with things to fix everything to function on V (mms, service, device type) and built from that, then it would all be fixed WHEN building a rom for OV ZVJ...
    I still dont see the point of building a ROM for ZVJ OV when we already have everything working for OV "ZVD" (zv4, 5, 9).. and since my fix more or less fixes this (with exception of MMS(still questionably working, as reported by a few testers) and data on GB)
    With just Root on the V, we have:
    Optimus V Roms(Froyo, GB, ICS, JB(soon)) with just about everything working(unless told otherwise)
    With Nitestalkr's method, we have:
    Optimus S ZVD roms with everything working(unless told otherwise).
    Optimus S ZVD roms with mostly everything working.(MMS has mixed reports for GB and ICS, Data has only 1 report of it working in GB(still unkown how it was accomplished), in JB mms isnt fixed in any Optimus build yet, in ICS and JB data IS working)
    With Sammyz method, we have:
    zvd roms with everything working, except mms won't work on the stock rom?
    zvj roms with everything working, except mms won't work on the stock rom?
    07-26-2012 07:09 PM
  2. sammyz's Avatar
    Using GitHub...
    My method, the main purose was ZVJ roms working, not ZVD....and it works with everyrhing except MMS. My method is ONLY for the advanced people. Your method is for, well, newbs lol, but I wish your method was found earlier. I was planning on flashing optimus s firmware later, but because of JB, I decided to start earlier...
    Sent from my Optimus V running Optimus S firmware on MetroPCS
    07-26-2012 07:29 PM
  3. nitestalkr's Avatar
    Both of our methods basically started because of jellybean, yours is more functional, but difficult, and yea, mines for the simpletons
    Yours us mainly for people who know what they're doing, PLUS, it gets data working for GB roms.
    Plus, if it wasn't for your method, and Jellybean ZVJ, my method wouldn't exist.
    All I need to do, is figure out how to "reactivate" or get data fixing, via my patch, or simple guide, for the ZVJ GB roms, and fix MMS completely(its half working).
    All you really need to do is fix MMS.
    So that's les work for your guide
    And data is more important than MMS, so you've got the favorable method.
    sent from my un-dead sammich.
    sammyz likes this.
    07-26-2012 08:30 PM
  4. thewraith420's Avatar
    I'm working on adding / editing your guide to possibly make getting data back easier
    sammyz likes this.
    07-26-2012 09:10 PM
  5. sammyz's Avatar
    Which guide?
    07-26-2012 09:21 PM
  6. thewraith420's Avatar
    Which guide?
    This one to get zvj on the V. I didn't finish it tho before I left for work. I'll pm you tomorrow with it.
    Edit:... DOH! or I could be posting in the wrong thread. Oh well, you know what I mean.
    sammyz likes this.
    07-26-2012 09:30 PM
  7. thewraith420's Avatar
    So Jonny5449 any new news?
    Sent from my VM670 using Tapatalk 2
    07-29-2012 08:25 AM
  8. ThatGuyLurkin's Avatar
    Jonny's last post was the one about the rom, which was around July 24th. :what:
    07-29-2012 11:57 AM
  9. sammyz's Avatar
    I'm guessing he got in trouble with parents ........
    Sent from my Optimus M
    inceyet likes this.
    07-29-2012 12:29 PM
  10. ThatGuyLurkin's Avatar
    Or realized its summer.
    07-29-2012 12:32 PM
  11. sammyz's Avatar
    Every other kid:
    It's summer????? :what:
    What am I doing here? I should go outside for the next month and not mess with android! Its very sunny and those beaches look pretty nice.
    Me: NO! It's hot outside, I love my air conditioned room where I can drink a mountain dew and not get dehydrated.
    jonny5449 likes this.
    07-29-2012 01:03 PM
  12. Nate456's Avatar
    Every other kid:
    ^Nate456 likes this idea But I have summer band to go to
    So has anyone been able to get a universal mms fix going yet.
    07-29-2012 02:42 PM
  13. sammyz's Avatar
    Ha, I play an electric 5-string bass, indoor instrument ^_^
    07-29-2012 02:51 PM
  14. nitestalkr's Avatar
    And I play vocals
    @nate, it looks like a universal flashable mms fix is out of reach for now.
    07-29-2012 04:02 PM
  15. thewraith420's Avatar
    And I play vocals
    True but looking around the S forums there really aren't many zvj roms if we worked out how to get one working with a flashable zip it probably wouldn't be hard to make one for each rom we want to use I'd love to see one for hydroROM and I'm thinking of checking out danteROM
    07-29-2012 04:15 PM
  16. Nate456's Avatar
    I can get MMS working. The problem, the fix is specific to each rom.
    07-29-2012 04:39 PM
  17. sammyz's Avatar
    Figured.
    07-29-2012 04:43 PM
  18. thewraith420's Avatar
    I've tried on hydroROM but had no luck. Can you pm me a fix lol
    07-29-2012 04:44 PM
  19. Nate456's Avatar
    Can you upload the build.prop, framework-res, and apns.conf.
    07-29-2012 05:00 PM
  20. thewraith420's Avatar
    Hydrorom.zip
    as requested
    Nate456 likes this.
    07-29-2012 05:21 PM
  21. Nate456's Avatar
    Should be good now your apns.conf file was wong. Everything else was good.
    Unzip, replace the apns.conf in system/etc
    nitestalkr likes this.
    07-29-2012 06:34 PM
  22. nitestalkr's Avatar
    I think I might be at fault for the apns.conf file, I think I included one in my patch, can't remember.. but maybe thats what's causing mms issues??
    07-29-2012 08:36 PM
  23. thewraith420's Avatar
    No..... I just looked at the files I sent you and I believe I sent the wrong files.... Sorry about that I guess I must have been more tired than i thought. I'll have to reupload early tomorrow morning when I get out of work
    Or i guess i could squeeze it in now lol and i have changed to dante rom now.... i like it better from what i've seen so far..
    http://www.mediafire.com/?1on8h1pb8xhvds2
    Nate456 likes this.
    07-29-2012 08:52 PM
  24. andrewnelson23's Avatar
    Dante is better than hydro? How so?
    07-29-2012 11:20 PM
  25. thewraith420's Avatar
    Just preferences.... I like the launcher included in Dante better then Hydro.. Their pretty similar roms.
    Tapatalk'n it from my VM670 running LS670ZVJ Dante Rom
    07-30-2012 12:05 AM
168 ... 4567
