cole2kb
Retired Moderator
Okay, so, it seems logical to think that they will be in the same place, although dependent on OS versions.
So, Froyo goes in one place, Gingerbread goes in another, and ICS goes in another, and Jellybean goes in another. If that is the case, and someone will need to research this, shouldn't take too long, then it would make much more sense to not "port" every ZVJ ROM, make a new tread, and commit to supporting it, and just create three flashable ZIPs, one for each OS, with the files being replaced, and instructing users on how to fix MMS by using GoSMS, unless that is as easy as replacing the files to fix the radio, and not independent of what ROM you're working off of.
